System Administration Guide: Basic Administration
SPARC: Examples—Changing the Default Boot Device
In this example, the default boot device is set to disk.
# init 0
INIT: New run level: 0
The system is down.
syncing file systems... done
Program terminated
ok setenv boot-device disk
boot-device =         disk
ok printenv boot-device
boot-device           disk                    disk
ok reset
Sun Ultra 5/10 UPA/PCI (UltraSPARC-IIi 333MHz), No Keyboard
OpenBoot 3.15, 128 MB memory installed, Serial #number.
Ethernet address number, Host ID: number.
Boot device: disk  File and args:
SunOS Release 5.9 Version 64-bit
pluto console login:
In this example, the default boot device is set to the network.
# init 0
The system is down.
Program terminated
ok setenv boot-device net
boot-device =         net
boot-device           net                    disk
ok reset
Boot device: net  File and args:
