A signed patch is a patch with a digital signature. A patch with a valid digital signature ensures that the patch has not been modified after the signature was applied to the patch. Using signed patches is a more secure method of downloading or adding patches because the patches include a digital signature that can be verified before the patch is added to your system.
Patches that are available for the Solaris 2.6, 7, 8, and 9 releases include a digital signature. Patches without a digital signature, or unsigned patches, are also available, but eventually, all patches will be signed patches. A valid digital signature ensures that the patch has not been modified since the signature was applied.
Signed patches are stored in Java archive format (JAR) files and are available from the SunSolve OnlineSM web site.
In previous Solaris releases, you could use the smpatch command with PatchPro to add signed patches to your system. For step-by-step instructions on using the smpatch command, see “Managing Signed Patches by Using Solaris Patch Management Tools (Tasks)” in Signed Patches Administration Guide for PatchPro 2.2.
In this Solaris release, you can use the patchadd command to add signed patches to your system. For step-by-step instructions on using the patchadd command, see Adding Signed Patches With patchadd Command (Task Map).
For additional overview information about signed patches, see Signed Packages and Patches.
