The following example shows how to remove the Solaris 8 patch, 111879–01 with the patchrm command.
# patchrm 111879-01 Checking installed patches... Backing out patch 111879-01... Patch 111874-02 has been backed out. # showrev -p | grep 111879-01 # |
The following example shows how to remove a Solaris 9 patch with the smpatch remove command.
# /usr/sadm/bin/smpatch remove -i 115028-01 Authenticating as user: root . . . |
