The following example shows how to uninstall the damaged ExampleSoft software. In this example, the uninstaller program is not readily available on a system backup.
# prodreg browse -m Examplesoft BROWSE # +/-/. UUID # NAME ======== ===== ==================================== = ============ 1 - root 1 System Registry 2 + a01ee8dd-1dd1-11b2-a3f2-0800209a5b6b 1 Solaris 9 8/03 System Software 3 + 8f64eabf-1dd2-11b2-a3f1-0800209a5b6b 1 Unclassified Software 4 - 95842091-725a-8501-ef29-0472985982be 1 ExampleSoft 233 . 90209809-9785-b89e-c821-0472985982be 1 Example Doc 234 . EXSOzzt 1 235 . EXSOblob 1 Example Data # prodreg uninstall -u 95842091-725a-8501-ef29-0472985982be -i 1 The install program requested could not be found # prodreg info -m "ExampleSoft" -a uninstallprogram uninstallprogram: /usr/bin/java -mx64m -classpath /var/sadm/prod/org.example.ExampleSoft/987573587 uninstall_ExampleSoft # ls /var/sadm/prod/org.example.ExampleSoft/987573587 /var/sadm/prod/org.example.ExampleSoft/987573587: No such file or directory # prodreg unregister -u 95842091-725a-8501-ef29-0472985982be -i 1 # pkgrm EXSOblob |
