Here are some guidelines for setting up efficient PATH variables:
If security is not a concern, put the current working directory (.) first in the path. However, including the current working directory in the path poses a security risk that you might want to avoid, especially for superuser.
Keep the search path as short as possible. The shell searches each directory in the path. If a command is not found, long searches can slow down system performance.
The search path is read from left to right, so you should put directories for commonly used commands at the beginning of the path.
Make sure directories are not duplicated in the path.
Avoid searching large directories, if possible. Put large directories at the end of the path.
Put local directories before NFSTM mounted directories to lessen the chance of “hanging” when the NFS server does not respond and to reduce unnecessary network traffic.
