The information in this chapter describes how to use GConf
to manage user preferences.
GConf
simplifies the administration of preferences
for users in the desktop environment. GConf
enables
system administrators to do the following:
Set mandatory values for particular preferences for all users. In this way, system administrators can control whether users can update particular preferences.
Set default values for particular preferences for all users.
Use suggested values for preferences that are specified in definition files for the preferences.
Read documentation on each preference.
GConf
also notifies applications when a preference
value changes, locally or across a network. In this way, when you change a
preference, all applications that use the preference are immediately updated.
GConf
has the following components:
A repository of user preferences.
A daemon, gconfd-2.
A command line tool, gconftool-2.
Each preference in the GConf
repository is
expressed as a key-value pair. A GConf preference key
is an element in the repository that corresponds to an application preference.
For example, the /apps/gnome-session/options/show_splash_screen
preference key corresponds to the Show splash screen on login
option in the Sessions
preference tool. The GNOME
Desktop user interface does not contain all of the preference keys in the GConf
repository. For example, the Sessions
preference tool does not contain an option that corresponds to the /apps/gnome-session/options/splash_screen_text key.
The repository is structured like a simple hierarchical file system. The repository contains the following:
Directories that correspond to applications that use the GConf
repository. For example, the file system contains the
directory /apps/metacity.
Subdirectories that correspond to categories of preferences. For example, the file system contains the directory /apps/metacity/general.
Special files that list the preference keys in the directory, and contain information about the keys. For example, a file that contains information about the keys that relate to the HTTP proxy preferences is in the directory /system/http_proxy.
A /schemas directory that contains files that describe all of the preference keys.
Preference keys typically have simple values such as strings, integers, or lists of strings and integers. The format of the preference key in the repository depends on the backend module that is used to read the repository. The following is an example of the /desktop/gnome/interface/font_name preference key when an Extensible Markup Language (XML) backend module is used to read the repository:
<entry name="font_name" mtime="1038323555" muser="user123" type="string"> <stringvalue>avantgarde 10</stringvalue></entry>
When this guide refers to a preference key, the path to the key is added to the name of the key. For example, the font_name preference key in the /desktop/gnome/interface subdirectory is referred to as /desktop/gnome/interface/font_name.
The GConf
repository contains
a series of storage locations that are called configuration sources. The configuration sources are listed in the GConf
path file. The location of the GConf
path file is /etc/gconf/version-number/path. Each user has a path file. Each line in the path file specifies
the following information:
The backend module to use to read the repository.
The permissions on the repository.
The location of the repository.
By default, the contents of the GConf
path
file are as follows:
xml:readonly:/etc/gconf/gconf.xml.mandatory include "$(HOME)/.gconf.path" xml:readwrite:$(HOME)/.gconf xml:readonly:/etc/gconf/gconf.xml.defaults
When GConf
searches for a preference value, GConf
reads the configuration sources in the order specified
in the path file. The following table describes the configuration sources
in the path file:
Configuration Source |
Description |
Mandatory |
The permissions on this configuration source are set to read only. Users cannot overwrite the values in this source, so the preferences in the source are mandatory. |
User |
This configuration source is stored in the .gconf directory in the home directory of the user. When the user sets a preference, the new preference information is added to this location. |
Default |
This configuration source contains the default preference settings. |
The sequence of the configuration sources in the path file ensures that
mandatory preference settings override user preference settings. The sequence
also ensures that user preference settings override default preference settings.
That is, GConf
applies preferences in the following
order of priority:
Mandatory preferences
User-specified preferences
Default preferences
The include instruction in the GConf
path file enables users to use another configuration source.
To use another configuration source, the user must specify the location of
the configuration source. The user specifies the location of the configuration
source in the home directory, in a file that is called .gconf.path.
A GConf schema is a collective term for a GConf schema key and a GConf schema object. The following table describes schema keys and schema objects and the relationship of these items to preference keys:
The following table gives examples of a preference key, a schema key, and a schema object:
Item |
Example |
Preference key |
/desktop/gnome/interface/font_name |
Schema key |
/schemas/desktop/gnome/interface/font_name |
Schema object |
<schema> <applyto>/desktop/gnome/interface/font_name</applyto> <key>/schemas/desktop/gnome/interface/font_name</key> <owner>gnome</owner> <type>string</type> <default>Sans 10</default> <locale name="C"> <short>Default font</short> <long>Name of the default font used by gtk+.</long> </locale> </schema> |
You can associate a schema key with a preference key. For example, the following /desktop/gnome/interface/font_name key includes a schema key:
<entry name="font_name" mtime="1034873859" schema="/schemas/desktop/gnome/interface/font_name"/>
When you associate a schema key with a preference key, the preference uses the suggested value that is specified in the schema object of the schema key. The suggested value is contained in the <default> element in the schema object. By default, all the preference keys in the default configuration source are associated with schema keys.
Typically, schemas are stored in the default configuration source.
Schemas are generated from schema definition files. A schema definition file defines the characteristics of all of the keys in a particular application. Schema definition files have a .schemas extension.
The schema definition files are included in the /etc/gconf/schemas directory. You can use the schema definition files to create a new configuration source.
Some schema definition files correspond closely to a part of the GNOME
Desktop user interface. For example, system_http_proxy.schemas
corresponds to the Network Proxy
preference tool.
Other schema definition files contain preference keys that are not present
in the GNOME Desktop user interface. For example, the /apps/gnome-session/options/splash_screen_text key is not present in the user interface.
Some parts of the GNOME Desktop user interface contain preferences that
represent preference keys from more than one schema definition file. For example,
the Keyboard Shortcuts
preference tool contains
preferences that represent keys from the panel-global-config.schemas and metacity.schemas files.
The GConf
daemon is called gconfd-2. The GConf
daemon notifies applications when a preference value changes.
For example, you might select to show only icons in toolbars in the Menus & Toolbars
preference tool. When you select this option
in the preference tool, the toolbars on all open applications are updated
instantly. The GConf
daemon can operate locally,
An instance of the GConf
daemon is started
for each user. The GConf
daemon does not have to
deal with complex problems such as authentication and data security. When
the GConf
daemon starts, the daemon loads the GConf
path file. The GConf
daemon
manages all access between applications and the configuration sources.
When an application requests the value of a preference key, the daemon searches the configuration sources as follows:
Search for the value of the preference key in each configuration source, in the order specified in the path file. If the value is found, return the value.
If a value is not found, search for the schema key that corresponds to the preference key in each configuration source, in the order specified in the path file.
If the schema key is found, check the value of the schema key.
If the value of the schema key is a schema object, return the suggested value in the <default> element of the schema object.
The GConf
daemon also caches preference key
values. All applications use this cache, so applications only need to access
the configuration sources once.
To terminate the GConf
daemon, run the following
command:
# gconftool-2 --shutdown
GConf
includes a
command line tool, gconftool-2. You can use the gconftool–2 command to perform the following tasks:
Set the values of keys.
Display the values of keys.
Install schemas from schema definition files when you install an application.
For example, use the following command to display the values of all keys in the /desktop/gnome directory and subdirectories.
# gconftool-2 --recursive-list /desktop/gnome
Table 1–1 lists some of the options that you can use with the gconftool-2 command.
Table 1–1 gconftool-2 Command Options
You can set a mandatory value or a
default value for a preference key. Before you change mandatory preference
values or default preference values for users, you must ensure that the GConf
daemon is not running for any user. Ensure that all users
are logged out before you change preference values for users.
To set a mandatory value or a default value for a preference key, use the gconftool-2 command, as follows:
# gconftool-2 --direct --config-source configuration-source --type data-type --set preference-key value
For example, to set wwwproxy.xyz.com as the mandatory HTTP proxy host, run the following command:
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.mandatory --type string --set /system/http_proxy/host wwwproxy.xyz.com
The user cannot override this preference value.
You can also use the gconftool-2 command to set default values. For example, to set the default number of workspaces to five, run the following command:
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.defaults --type int --set /apps/metacity/general/num_workspaces 5
The user can override this preference value.
Before you change mandatory preference values or default preference values for users, you must ensure that all users are logged out.
The following sections describe how to assign mandatory or default values to general preferences.
To set HTTP proxy preferences, you modify the values of the preference keys in the /system/http_proxy/ location. For example, to set a mandatory value for the HTTP proxy host, run the following command:
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.mandatory --type string --set /system/http_proxy/host proxy-name
To set a default value for the HTTP proxy host, run the following command:
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.defaults --type string --set /system/http_proxy/host proxy-name
You can also set other HTTP proxy-related preferences. For information on the other HTTP proxy preferences, see the system_http_proxy.schemas schema definition file.
To set print manager preferences, you modify the values of the preference keys in the /apps/gnome-print-manager location. For example, if you do not want users to view the print jobs of other users, set a mandatory value as follows:
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.mandatory --type bool --set /apps/gnome-print-manager/show_all_jobs false
To set a default value for this preference, run the following command:
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.defaults --type bool --set /apps/gnome-print-manager/show_all_jobs false
You can also set other print manager preferences. For information on the other print manager preferences, see the gnome-print-manager.schemas schema definition file.
To set a mandatory number of workspaces, use the following command:
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.mandatory --type int --set /apps/metacity/general/num_workspaces integer
To set a default number of workspaces, use the following command:
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.defaults --type int --set /apps/metacity/general/num_workspaces integer
You can also set other window manager preferences. For information on the other window manager preferences, see the metacity.schemas schema definition file.
To set keyboard accessibility preferences, you modify the values of the preference keys in the /desktop/gnome/accessibility/keyboard location. For example, if you want to set a mandatory value so that keyboard accessibility features are enabled, run the following command:
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.mandatory --type bool --set /desktop/gnome/accessibility/keyboard/enable true
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.defaults --type bool --set desktop/gnome/accessibility/keyboard/enable false
You can also set other keyboard accessibility preferences. For information on the other keyboard accessibility preferences, see the desktop_gnome_accessibility_keyboard.schemas schema definition file.
To set keyboard shortcut preferences, you modify the values of preference keys in two locations. The following table shows the locations to modify, and the part of the user interface to which the locations correspond:
GConf Location |
User Interface Component |
/apps/panel/global |
/apps/metacity/general |
For example, you might want users to use only the Alt + F3 keyboard shortcut to open the Run Program dialog. To set this mandatory value, run the following command:
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.mandatory --type string --set /apps/panel/global/run_key '<Alt>F3'
You might want users to use Alt + F11 to maximize windows, by default. To set this default value, run the following command:
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.defaults --type string --set /apps/metacity/window_keybindings/maximize '<Alt>F11'
You can also set other keyboard shortcut preferences. For information on the other keyboard shortcut preferences, see the panel-global-config.schemas and metacity.schemas schema definition files.
To set global preferences for panels, you modify the values of the preference keys in the /apps/panel/global location. For example, if you do not want users to ever use panel animation, set a mandatory value as follows:
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.mandatory --type bool --set /apps/panel/global/enable_animations false
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.defaults --type bool --set /apps/panel/global/enable_animations false
You can also set other global panel preferences. For information on the other global panel preferences, see the panel-global-config.schemas schema definition file.
The panel-per-panel-config.schemas schema definition file specifies the following details of the panels in the desktop environment:
Number of panels.
Types of the panels.
Properties of the panels.
Contents of the panels.
The configuration of individual panels and of panel objects is a complex task. To configure individual panels and panel objects, you must first understand the structure of the panel-per-panel-config.schemas schema definition file. For more information on the panel-per-panel-config.schemas schema definition file, see the next section.
To set preferences for individual panels and panel objects, you must set the values of many preferences in a configuration source. The easiest way to set the values of many preferences is to use a script. For a sample script that sets preferences for a panel and objects on the panel, see Sample Script for Setting Individual Panel Preferences.
The schema definition file panel-per-panel-config.schemas contains sections that specify panels and panel contents for small, medium, and large screens. The section for small screens and the section for large screens are not functional at the time of publication of this guide. To learn about preference keys for panels or panel objects, read the section for medium screens only.
The medium section of the file panel-per-panel-config.schemas is structured as follows:
Preference keys that specify the general structure of panels, applets, and other panel objects in the desktop environment. The following keys specify the number of panels, applets, and other panel objects that appear in the desktop environment:
/apps/panel/default_profiles/medium/general/panel_id_list
/apps/panel/default_profiles/medium/general/applet_id_list
/apps/panel/default_profiles/medium/general/object_id_list
The keys also assign identifiers to each panel, applet, and panel object. For example, the following excerpt from panel-per-panel-config.schemas specifies that two panels appear in the desktop environment:
<key>/schemas/apps/panel/default_profiles/medium/ general/panel_id_list</key> . . . <default>[00000001,00000002]</default>
In panel-per-panel-config.schemas, the identifier 00000001 identifies the bottom edge panel, and the identifier 00000002 identifies the Menu Panel.
Preference keys that specify the properties of the panels. The panel property keys are structured as follows:
/apps/panel/default_profiles/medium/panels/panel-number/panel-property-key
For example, the key /apps/panel/default_profiles/medium/panels/00000001/screen_edge specifies the edge of the display on which the bottom edge panel resides.
The keys that specify the properties of the bottom edge panel are listed first. The keys that specify the properties of the Menu Panel are listed at the end of the medium section in panel-per-panel-config.schemas.
Preference keys that list the panel objects, the panel object properties, and the panels in which the objects reside. For example, the following excerpt from panel-per-panel-config.schemas specifies object 00000001:
<key>/schemas/apps/panel/default_profiles/medium/ objects/00000001/object_type</key> . . . <default>launcher-object</default> . . . <key>/schemas/apps/panel/default_profiles/medium/ objects/00000001/launcher_location</key> . . . <default>applications:///nautilus.desktop</default> . . . <key>/schemas/apps/panel/default_profiles/medium/ objects/00000001/panel_id</key> . . . <default>00000002</default>
The object is a launcher that starts Nautilus
file manager. The launcher resides in the Menu Panel.
Preference keys that list the applets, the applet preferences, and the panels in which the applets reside. For example, the following excerpt from panel-per-panel-config.schemas specifies applet 00000001:
<key>/schemas/apps/panel/default_profiles/medium/ applets/00000001/object_type</key> . . . <default>bonobo-applet</default> . . . <key>/schemas/apps/panel/default_profiles/medium/ applets/00000001/panel_id</key> . . . <default>00000001</default> . . . <key>/schemas/apps/panel/default_profiles/medium/ applets/00000001/bonobo_iid</key> . . . <default>OAFIID:GNOME_TasklistApplet</default>
The applet is the Window List
applet. The
applet resides in the bottom edge panel.
This section contains a sample script that sets the preferences for a panel that has the following major characteristics:
The panel is an edge panel, and resides at the bottom edge of the screen.
The panel contains a file manager launcher and a Terminal
launcher.
The panel contains a Window List
applet.
The sample script also sets other minor preferences. All of the preferences have default values, not mandatory values.
The sample script follows:
# Usage is: set_key <type> <key> <value> <extra options if any> function set_key() { TYPE="$1" shift KEY="$1" shift VALUE="$1" shift OTHER_ARGS="$*" gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.defaults --owner=panel $OTHER_ARGS --type "$TYPE" --set "$KEY" "$VALUE" } # Define the number of panels, the number of launchers, and the number of applets set_key list /apps/panel/default_profiles/medium/general /panel_id_list [00000001] --list-type string set_key list /apps/panel/default_profiles/medium/general /object_id_list [00000001,00000002] --list-type string set_key list /apps/panel/default_profiles/medium/general /applet_id_list [00000001] --list-type string # Define the characteristics of the panel set_key string /apps/panel/default_profiles/medium/panels /00000001/panel_type edge-panel set_key string /apps/panel/default_profiles/medium/panels /00000001/panel_size panel-size-x-small set_key string /apps/panel/default_profiles/medium/panels /00000001/screen_edge panel-edge-bottom set_key bool /apps/panel/default_profiles/medium/panels /00000001/hide_buttons_enabled false set_key string /apps/panel/default_profiles/medium/panels /00000001/panel_background_type no-background # Define the first launcher set_key string /apps/panel/default_profiles/medium/objects /00000001/object_type launcher-object set_key string /apps/panel/default_profiles/medium/objects /00000001/launcher_location 'applications:///nautilus.desktop' set_key string /apps/panel/default_profiles/medium/objects /00000001/panel_id 00000001 set_key int /apps/panel/default_profiles/medium/objects /00000001/position 20 # Define the second launcher set_key string /apps/panel/default_profiles/medium/objects /00000002/object_type launcher-object set_key string /apps/panel/default_profiles/medium/objects /00000002/launcher_location 'applications:///System/gnome-terminal.desktop' set_key string /apps/panel/default_profiles/medium/objects /00000002/panel_id 00000001 set_key int /apps/panel/default_profiles/medium/objects /00000002/position 25 # Define the applet set_key string /apps/panel/default_profiles/medium/applets /00000001/object_type bonobo-applet set_key string /apps/panel/default_profiles/medium/applets /00000001/bonobo_iid OAFIID:GNOME_TasklistApplet set_key string /apps/panel/default_profiles/medium/applets /00000001/panel_id 00000001 set_key int /apps/panel/default_profiles/medium/applets /00000001/position 25
The following sections describe how to assign mandatory or default values to look-and-feel preferences.
To set font preferences, you modify the values of two preference keys. The following table shows the keys to modify, and the part of the user interface to which the keys correspond:
GConf Location |
/apps/nautilus/preferences/desktop_font |
For example, to set Sans 12 as the mandatory application font, run the following command:
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.mandatory --type string --set /desktop/gnome/interface/font_name “Sans 12”
To set palatino 12 as the default desktop object font, run the following command:
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.defaults --type string --set /apps/nautilus/preferences/desktop_font “palatino 12”
To set desktop background preferences, you modify the values of the preference keys in the /desktop/gnome/background location. For example, to set a mandatory image for the desktop background, run the following command:
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.mandatory --type string --set /desktop/gnome/background/picture_filename filename.png
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.defaults --type string --set /desktop/gnome/background/picture_filename filename.png
You can also set other desktop background preferences. For information on the other desktop background preferences, see the desktop_gnome_background.schemas schema definition file.
To set splash image preferences, you modify the value of the preference keys in the /apps/gnome-session/options/ location. For example, if you do not want users ever to see a splash image, set a mandatory value as follows:
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.mandatory --type bool --set /apps/gnome-session/options/show_splash_screen false
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.defaults --type bool --set /apps/gnome-session/options/show_splash_screen false
You can also set other splash image preferences. For information on the other splash image preferences, see the gnome-session.schemas schema definition file.
To restore the default preference values for a user, run the following command:
# gconftool-2 --direct --config-source user-configuration-source --recursive-unset
Replace user-configuration-source with the configuration source in the .gconf directory in the home directory of the user.
This command resets the values of all preference keys, in all subdirectories, from the user setting to the setting in the default configuration source.
