GNOME 2.0 Desktop for the Solaris Operating Environment System Administration Guide
To Set Print Manager Preferences
To set print manager preferences, you modify the values of the preference keys in the /apps/gnome-print-manager location. For example, if you do not want users to view the print jobs of other users, set a mandatory value as follows:
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.mandatory --type bool --set /apps/gnome-print-manager/show_all_jobs false
To set a default value for this preference, run the following command:
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.defaults --type bool --set /apps/gnome-print-manager/show_all_jobs false
You can also set other print manager preferences. For information on the other print manager preferences, see the gnome-print-manager.schemas schema definition file.
