The panel-per-panel-config.schemas schema definition file specifies the following details of the panels in the desktop environment:
Number of panels.
Types of the panels.
Properties of the panels.
Contents of the panels.
The configuration of individual panels and of panel objects is a complex task. To configure individual panels and panel objects, you must first understand the structure of the panel-per-panel-config.schemas schema definition file. For more information on the panel-per-panel-config.schemas schema definition file, see the next section.
To set preferences for individual panels and panel objects, you must set the values of many preferences in a configuration source. The easiest way to set the values of many preferences is to use a script. For a sample script that sets preferences for a panel and objects on the panel, see Sample Script for Setting Individual Panel Preferences.
The schema definition file panel-per-panel-config.schemas contains sections that specify panels and panel contents for small, medium, and large screens. The section for small screens and the section for large screens are not functional at the time of publication of this guide. To learn about preference keys for panels or panel objects, read the section for medium screens only.
The medium section of the file panel-per-panel-config.schemas is structured as follows:
Preference keys that specify the general structure of panels, applets, and other panel objects in the desktop environment. The following keys specify the number of panels, applets, and other panel objects that appear in the desktop environment:
/apps/panel/default_profiles/medium/general/panel_id_list
/apps/panel/default_profiles/medium/general/applet_id_list
/apps/panel/default_profiles/medium/general/object_id_list
The keys also assign identifiers to each panel, applet, and panel object. For example, the following excerpt from panel-per-panel-config.schemas specifies that two panels appear in the desktop environment:
<key>/schemas/apps/panel/default_profiles/medium/ general/panel_id_list</key> . . . <default>[00000001,00000002]</default>
In panel-per-panel-config.schemas, the identifier 00000001 identifies the bottom edge panel, and the identifier 00000002 identifies the Menu Panel.
Preference keys that specify the properties of the panels. The panel property keys are structured as follows:
/apps/panel/default_profiles/medium/panels/panel-number/panel-property-key
For example, the key /apps/panel/default_profiles/medium/panels/00000001/screen_edge specifies the edge of the display on which the bottom edge panel resides.
The keys that specify the properties of the bottom edge panel are listed first. The keys that specify the properties of the Menu Panel are listed at the end of the medium section in panel-per-panel-config.schemas.
Preference keys that list the panel objects, the panel object properties, and the panels in which the objects reside. For example, the following excerpt from panel-per-panel-config.schemas specifies object 00000001:
<key>/schemas/apps/panel/default_profiles/medium/ objects/00000001/object_type</key> . . . <default>launcher-object</default> . . . <key>/schemas/apps/panel/default_profiles/medium/ objects/00000001/launcher_location</key> . . . <default>applications:///nautilus.desktop</default> . . . <key>/schemas/apps/panel/default_profiles/medium/ objects/00000001/panel_id</key> . . . <default>00000002</default>
The object is a launcher that starts Nautilus
file manager. The launcher resides in the Menu Panel.
Preference keys that list the applets, the applet preferences, and the panels in which the applets reside. For example, the following excerpt from panel-per-panel-config.schemas specifies applet 00000001:
<key>/schemas/apps/panel/default_profiles/medium/ applets/00000001/object_type</key> . . . <default>bonobo-applet</default> . . . <key>/schemas/apps/panel/default_profiles/medium/ applets/00000001/panel_id</key> . . . <default>00000001</default> . . . <key>/schemas/apps/panel/default_profiles/medium/ applets/00000001/bonobo_iid</key> . . . <default>OAFIID:GNOME_TasklistApplet</default>
The applet is the Window List applet. The
applet resides in the bottom edge panel.
This section contains a sample script that sets the preferences for a panel that has the following major characteristics:
The panel is an edge panel, and resides at the bottom edge of the screen.
The panel contains a file manager launcher and a Terminal launcher.
The panel contains a Window List
applet.
The sample script also sets other minor preferences. All of the preferences have default values, not mandatory values.
The sample script follows:
# Usage is: set_key <type> <key> <value> <extra options if any>
function set_key()
TYPE="$1"
shift
KEY="$1"
shift
VALUE="$1"
shift
OTHER_ARGS="$*"
gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.defaults
--owner=panel $OTHER_ARGS --type "$TYPE" --set "$KEY" "$VALUE"
# Define the number of panels, the number of launchers, and the number of applets
set_key list /apps/panel/default_profiles/medium/general
/panel_id_list [00000001] --list-type string
/object_id_list [00000001,00000002] --list-type string
/applet_id_list [00000001] --list-type string
# Define the characteristics of the panel
set_key string /apps/panel/default_profiles/medium/panels
/00000001/panel_type edge-panel
/00000001/panel_size panel-size-x-small
/00000001/screen_edge panel-edge-bottom
set_key bool /apps/panel/default_profiles/medium/panels
/00000001/hide_buttons_enabled false
/00000001/panel_background_type no-background
# Define the first launcher
set_key string /apps/panel/default_profiles/medium/objects
/00000001/object_type launcher-object
/00000001/launcher_location 'applications:///nautilus.desktop'
/00000001/panel_id 00000001
set_key int /apps/panel/default_profiles/medium/objects
/00000001/position 20
# Define the second launcher
/00000002/object_type launcher-object
/00000002/launcher_location 'applications:///System/gnome-terminal.desktop'
/00000002/panel_id 00000001
/00000002/position 25
# Define the applet
set_key string /apps/panel/default_profiles/medium/applets
/00000001/object_type bonobo-applet
/00000001/bonobo_iid OAFIID:GNOME_TasklistApplet
set_key int /apps/panel/default_profiles/medium/applets
/00000001/position 25
