GNOME 2.0 Desktop for the Solaris Operating Environment System Administration Guide
To Set Splash Image Preferences
To set splash image preferences, you modify the value of the preference keys in the /apps/gnome-session/options/ location. For example, if you do not want users ever to see a splash image, set a mandatory value as follows:
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.mandatory --type bool --set /apps/gnome-session/options/show_splash_screen false
To set a default value for this preference, run the following command:
# gconftool-2 --direct --config-source xml:readwrite:/etc/gconf/gconf.xml.defaults --type bool --set /apps/gnome-session/options/show_splash_screen false
You can also set other splash image preferences. For information on the other splash image preferences, see the gnome-session.schemas schema definition file.
