A GConf schema is a collective term for a GConf schema key and a GConf schema object. The following table describes schema keys and schema objects and the relationship of these items to preference keys:
The following table gives examples of a preference key, a schema key, and a schema object:
Item |
Example |
Preference key |
/desktop/gnome/interface/font_name |
Schema key |
/schemas/desktop/gnome/interface/font_name |
Schema object |
<schema>
<applyto>/desktop/gnome/interface/font_name</applyto>
<key>/schemas/desktop/gnome/interface/font_name</key>
<owner>gnome</owner>
<type>string</type>
<default>Sans 10</default>
<locale name="C">
<short>Default font</short>
<long>Name of the default font used by gtk+.</long>
</locale>
</schema>
You can associate a schema key with a preference key. For example, the following /desktop/gnome/interface/font_name key includes a schema key:
<entry name="font_name" mtime="1034873859" schema="/schemas/desktop/gnome/interface/font_name"/>
When you associate a schema key with a preference key, the preference uses the suggested value that is specified in the schema object of the schema key. The suggested value is contained in the <default> element in the schema object. By default, all the preference keys in the default configuration source are associated with schema keys.
Typically, schemas are stored in the default configuration source.
