Default screensaver preferences are stored in a file that is called XScreenSaver. This file is stored in different locations, depending on the platform, as follows:
Platform |
File Location |
RedHat Linux |
/usr/X11R6/lib/X11/app-defaults/XScreenSaver |
Solaris Operating Environment |
/usr/openwin/lib/app-defaults/XScreenSaver |
To modify screensaver application preferences, users can use the Screensaver preference tool. To start the Screensaver preference tool, choose Applications -> Desktop Preferences -> Screensaver from the Menu Panel. When a user modifies
the screensaver preferences, the preferences are stored in the home directory
of the user, in the $HOME/.xscreensaver file. For
information on screensaver preferences, see the GNOME 2.0 Desktop for the Solaris Operating
Environment User Guide.For information
on screensaver preferences, see GNOME 2.2 Desktop User Guide.
Users can also run the command /usr/X11R6/bin/xscreensaver-demo to open the XScreenSaver dialog.
Users can also run the command /usr/openwin/bin/xscreensaver-demo to open the XScreenSaver dialog.
To set default screensaver preferences for all users, modify the XScreenSaver file. You can also use the XScreenSaver dialog to create a $HOME/.xscreensaver file, then copy the file to the location of the XScreenSaver file.
To restore the default settings for a user, delete the $HOME/.xscreensaver file from the home directory of the user. If no $HOME/.xscreensaver file is present, the default preferences in the XScreenSaver file are used.
The default display behavior of XScreenSaver
is to display a blank screen. The blank screen might confuse users. You might
want to change this default display behavior.
To activate changes to the screensaver preferences, use the following command to reload screensaver preferences:
# xscreensaver-command -restart
The xset application does not work
with XScreenSaver at the time of publication of
this guide. To modify screensaver preferences, modify the XScreenSaver file or the $HOME/.xscreensaver file.
