Problem |
Bug ID 4818711, affects all locales. When you launch GNOME applications from a terminal, you might occasionally see warning messages in the terminal window. |
Solution |
These warnings do not appear if you launch applications from the desktop environment menus. These warnings do not affect the functionality of the application. This bug will be fixed in a future release of the GNOME Desktop. |
