GNOME 2.0 Desktop for the Solaris Operating Environment Troubleshooting Guide
9.4.12 Character Display Problem in Terminal
Problem
Affects Japanese locales.
In the Terminal application Preferences dialog, IBM/NEC extended character and special characters are not displayed when you select the option Use the same font as other applications.
Solution
Perform the following steps:
  • Open a terminal.
  • Choose Edit -> Current Profiles.
  • In the Editing Profiles dialog, deselect the option Use the same font as other applications.
  • Specify the font to be interface user.
