Problem
For example: bug ID
4805328, affects some locales, including Chinese locales.
Currently,
you cannot set the default font for the GNOME Desktop for each locale. As
a result, particularly if you are switching between locales, you might find
that the default desktop font is either too small or is rendered blank.
