Use the following locales,
which are supported by the pango X11 shaper, until CP1251 support is available:
ru_RU.KOI8-R
ru_RU.ISO8859-5
ru_RU.UTF-8
You can use iconv conversion tables to re-encode CP1251
and ANSI1251 files. To encode a CP1251 or ANSI1251 file into a UTF-8 encoded
file, in a terminal run the following command:
/usr/bin/iconv
-f CP1251 -t UTF-8 CP1251 filename > UTF-8 filename. (man iconv)
