In most cases, new subdomains are usually created from the start with a new network and new machines, or split off from an existing domain. The process is essentially similar in both cases.
Once you have planned your new subdomain, do the following.
Make sure all of the machines in the new subdomain are properly set up as DNS clients.
If you are carving a new subdomain out of an existing domain, most of the machines are probably already set up of DNS clients. If you add new machines to an existing network, you must install properly configured resolv.conf and nsswitch.conf files on each machine.
Install properly configured configuration and DNS zone data files on the subdomain's master server.
/etc/named.conf
/var/named/named.ca
/var/named/hosts
/var/named/hosts.rev
/var/named/named.local
The server host files must have an Address (A) record along with any necessary CNAME records for each machine in the subdomain. The server hosts.rev files must have a pointer (PTR) record for each machine in the subdomain. HINFO and WKS records can also be added.
If you are splitting a domain, remove the new subdomain machines records from the master server hosts and hosts.rev files.
You must delete the A records for the machines that are now in the new subdomain from the hosts files of the old domain's servers. You must also delete the PTR records for those machines from the old domain's hosts.rev files. Any optional HINFO and WKS records for the moved machines should also be deleted.
If you divide an existing domain, add the new subdomain name to CNAME records in the master server's hosts file.
For example, suppose you use the machine aldebaran as a fax server. The fax server has the following CNAME record in the hosts file of the parent domain's servers.
faxserver IN CNAME aldebaran |
You would create a faxserver CNAME record for aldebaran in the new master server's hosts file. You would also change this CNAME record in the parent domain's hosts file to include aldebaran's subdomain:
faxserver IN CNAME aldebaran.manf.doc.com |
Add NS records for the new subdomain's servers to the parent domain's hosts file.
For example, say your parent domain is doc.com. You create a new manf.doc.com subdomain with the machine rigel as manf's master server. aldebaran is the slave server. You would add the following records to the hosts file of doc.com's master server.
manf.doc.com 99999 IN NS rigel.manf.doc.com
99999 IN NS aldebaran.manf.doc.com
Add A records for the new subdomain's servers to the parent domain's hosts file.
You would then add the following records to the hosts file of doc.com's master server.
rigel.manf.doc.com 99999 IN A 1.22.333.121 aldebaran.manf.doc.com 99999 IN A 1.22.333.136 |
Start up in.named on the subdomain's servers.
# /usr/sbin/in.named
Instead of running in.named from the command line, reboot. See in.named and DNS Name Servers.
