System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Selecting a Different Configuration File
When you change a machine's naming service, you need to modify that machine's switch file accordingly. For example, if you change a machine's naming service from NIS to NIS+, you need to install a switch file appropriate for NIS+. You change switch files by copying the appropriate template file to nsswitch.conf.
If you are installing NIS+ on a machine using the NIS+ installation scripts, the NIS+ template script is copied to nsswitch.conf for you. In this case, you do not have to configure the switch file unless you want to customize.
Before proceeding to change switch files, make sure the sources listed in the file are properly set up. In other words, if you are going to select the NIS+ version, the client must eventually have access to NIS+ service. If you select the local files version, those files must be properly set up on the client.
How to Modify the Name Service Switch
To change to a switch file, follow these steps.
  1. Become superuser.
  2. Copy the appropriate alternate file for the machine's naming service over the nsswitch.conf file.
    NIS+ Version (done automatically for you by NIS+ scripts)
    client1# cd /etc
    client1# cp nsswitch.nisplus nsswitch.conf
    NIS Version
    client1# cd /etc
    client1# cp nsswitch.nis nsswitch.conf
    Local /etc Files Version
    client1# cd /etc
    client1# cp nsswitch.files nsswitch.conf
  3. Reboot the machine.
    The nscd daemon caches switch information. Some library routines do not periodically check the nsswitch.conf file to see whether the file has been changed. You must reboot the machine to make sure that the daemon and those routines have the latest information in the file.
Note –
In order to use LDAP naming services, you must also properly configure all LDAP client machines, in addition to modifying the nsswitch.conf. See Chapter 16, Setting Up Clients (Tasks) for more information.
