This section shows the files you need to implement DNS for a sample Internet-connected network, based on the examples used in this chapter.
The IP addresses and network numbers used in examples and code samples in this manual are for illustration purposes only. Do not use them as shown because they might have been assigned to an actual network or host.
This example assumes the following.
An environment connected to the Internet
Two networks, each with its own domain (doc.com and sales.doc.com) and its own DNS zone
The doc.com domain and zone is the top zone over the sales.doc.com subdomain and zone
Each network has its own network number
Table 5–1 Example Network Domain and Zone Configuration
Name and Zone |
Number |
doc.com |
123.45.6 |
sales.doc.com |
111.22.3 |
Each zone has a master and one slave server, and the slave server of sales.doc.com is also the master server of doc.com
Table 5–2 Example Network DNS Servers
Zone |
Host Name |
Function |
Address | CNAME |
doc.com |
sirius |
master for doc.com |
123.45.6.1 | dnsmaster |
doc.com |
deneb |
slave for doc.com |
111.22.3.5 | dnssecond |
sales.doc.com |
altair |
master for sales.doc.com |
111.22.3.4 | dnssales |
sales.doc.com |
altair |
slave for sales.doc.com |
The following code examples show configuration files for the three servers in the two networks.
; ; Sample named.conf file on dnsmastr (sirius) name server ; ; global options and defaults ; options { directory "/var/named"; }; ; master zone definitions ; zone "doc.com" in { type master; file "db.doc.com"; }; zone "6.45.123.in-addr.arpa" in { type master; file "db.123.45.6"; }; zone "0.0.127.in-addr.arpa" in { type master; file "db.127.0.0"; }; ; slave server definitions ; zone "sales.doc.com" in { type slave; file "tmp.db.sales"; masters { 111.22.3.4; }; }; zone "3.22.111.in-addr.arpa" in { type slave; file "tmp.db.111.22.3"; masters { 111.22.3.4; }; }; ; root hints zone "." in { type hint; file "named.ca"; }; |
; ; Sample named.conf file on the dnssales (altair) name server ; options { directory "/var/named"; }; zone "sales.doc.com" in { type master; file "db.sales.doc.com"; }; zone "3.22.111.in-addr.arpa" in { type master; file "db.111.22.3"; }; zone "0.0.127.in-addr.arpa" in { type master; file "db.127.0.0"; }; ; root hints zone "." in { type hint; file "named.ca"; }; |
; ;S ample named.conf file on the dnssecond (deneb) name server ; options { directory "/var/named"; }; zone "doc.com" in { type slave; file "tmp.db.doc.com"; masters { 123.45.6.1; }; }; zone "6.45.123.in-addr.arpa" in { type slave; file "tmp.db.123.45.6"; masters { 123.45.6.1; }; }; zone "0.0.127.in-addr.arpa" in { type master; file "db.127.0.0"; }; ; root hints zone "." in { type hint; file "named.ca"; }; |
The following code examples show resolv.conf files for the three servers in the two networks. If the host in question is not running in.named, the local host address should not be used as a name server.
; ; /etc/resolv.conf file for dnsmaster (sirius) ; domain doc.com nameserver 0.0.0.0 nameserver 111.22.3.5 |
; ; /etc/resolv.conf file for dnssales (altair) ; domain sales.doc.com nameserver 111.22.3.4 nameserver 123.45.6.1 |
; ; /etc/resolv.conf for dnssecond ; domain doc.com nameserver 111.22.3.5 nameserver 123.45.6.1 |
The following code example shows the named.local file used by the two master servers on the two networks. Both servers have the same file.
$TTL 5h ; SOA rec 0.0.127.in-addr.arpa. IN SOA siriusdoc.com. sysop.centauri.doc.com.( 19970331 ; serial number 10800 ; refresh every 3 hours 10800 ; retry every 3 hours 604800 ; expire after a week 86400 ) ; TTL of 1 day ; Name Servers 0.0.127.in-addr.arpa. IN NS sirius.doc.com. 0.0.127.in_addr.arpa IN NS dnssecond.doc.com 1 IN PTR localhost. |
The following code examples show db.doc and db.sales files for the two master servers on the two networks.
$TTL 5h ; SOA rec doc.com. IN SOA sirius.doc.com. sysop.centauri.doc.com. ( 19970332 ; serial number 10800 ; refresh every 3 hours 10800 ; retry every 3 hours 604800 ; expire after a week 86400 ) ; TTL of 1 day ; Name Servers doc.com. IN NS sirius.doc.com. sales.doc.com. IN NS altair.sales.doc.com. ; Addresses localhost IN A 127.0.0.1 sirius IN A 123.45.6.1 rigel IN A 123.45.6.112 antares IN A 123.45.6.90 polaris IN A 123.45.6.101 procyon IN A 123.45.6.79 tauceti IN A 123.45.6.69 altair.sales.doc.com. N A 111.22.3.4 ; aliases dnsmastr IN CNAME sirius.doc.com. dnssecond.doc.com IN CNAME deneb.doc.com |
$TTL 5h ; SOA rec sales.doc.com. IN SOA altair.sales.doc.com. sysop.polaris.doc.com. ( 19970332 ; serial number 10800 ; refresh every 3 hours 10800 ; retry every 3 hours 604800 ; expire after a week 86400 ) ; TTL of 1 day ; Name Servers doc.com. IN NS sirius.doc.com. sales.doc.com. IN NS altair.sales.doc.com. ; Addresses altair IN A 111.22.3.4 localhost IN A 127.0.0.1 sirius.doc.com. IN A 123.45.6.1 luna IN A 192.168.8.22 phoebus IN A 192.168.8.24 deimos IN A 192.168.8.25 ganymede IN A 192.168.8.27 europa IN A 192.168.8.28 callisto IN A 192.168.8.29 ; ; aliases dnssales.sales.doc.com IN CNAME altair.sales.doc.com |
The following code examples show hosts.rev files for the two master servers on the two networks.
$TTL 5h ; SOA rec 6.45.123.in-addr.arpa. IN SOA sirius.doc.com. sysop.centauri.doc.com. ( 19970331 ; serial number 10800 ; refresh every 3 hours 10800 ; retry every 3 hours 604800 ; expire after a week 86400 ) ; TTL of 1 day ; Name Servers 6.45.123.in-addr.arpa. IN NS sirius.doc.com. ;Pointer records for 123.45.6 1 IN PTR sirius.doc.com. 112 IN PTR rigel.doc.com. 90 IN PTR antares.doc.com. 101 IN PTR polaris.doc.com. 79 IN PTR procyon.doc.com. 69 IN PTR tauceti.doc.com. |
$TTL 5h ; SOA rec 3.22.111.in-addr.arpa. IN SOA altair.sales.doc.com. \ sysop.polaris.doc.com.( 19970331 ; serial number 10800 ; refresh every 3 hours 10800 ; retry every 3 hours 604800 ; expire after a week 86400 ) ; TTL of 1 day ; Name Servers 3.22.111.in-addr.arpa. IN NS altair.sales.doc.com.; \ Pointer records for 111.22.3 22 IN PTR luna 23 IN PTR deneb 24 IN PTR phoebus 25 IN PTR deimos 26 IN PTR altair 27 IN PTR ganymede 28 IN PTR europa 29 IN PTR callisto |
The following code example shows the named.ca file that is stored on each of the two master servers on the two networks. Both servers use identical named.ca files.
; ; formerly NS1.ISI.EDU . 3600000 NS B.ROOT-SERVERS.NET. B.ROOT-SERVERS.NET. 3600000 A 128.9.0.107 ; ; formerly C.PSI.NET . 3600000 NS C.ROOT-SERVERS.NET. C.ROOT-SERVERS.NET. 3600000 A 192.33.4.12 ; ; formerly TERP.UMD.EDU . 3600000 NS D.ROOT-SERVERS.NET. D.ROOT-SERVERS.NET. 3600000 A 128.8.10.90 ; ; formerly NS.NASA.GOV ;. 3600000 NS E.ROOT-SERVERS.NET. E.ROOT-SERVERS.NET. 3600000 A 192.203.230.10 ; ; formerly NS.ISC.ORG . 3600000 NS F.ROOT-SERVERS.NET. F.ROOT-SERVERS.NET. 3600000 A 192.5.5.241 ; ; formerly NS.NIC.DDN.MIL . 3600000 NS G.ROOT-SERVERS.NET. G.ROOT-SERVERS.NET. 3600000 A 192.112.36.4 ; ; formerly AOS.ARL.ARMY.MIL . 3600000 NS H.ROOT-SERVERS.NET. H.ROOT-SERVERS.NET. 3600000 A 128.63.2.53 ; ; formerly NIC.NORDU.NET . 3600000 NS I.ROOT-SERVERS.NET. I.ROOT-SERVERS.NET. 3600000 A 192.36.148.17 ; ; temporarily housed at NSI (InterNIC) . 3600000 NS J.ROOT-SERVERS.NET. J.ROOT-SERVERS.NET. 3600000 A 198.41.0.10 ; ; temporarily housed at NSI (InterNIC) . 3600000 NS K.ROOT-SERVERS.NET. K.ROOT-SERVERS.NET. 3600000 A 198.41.0.11 ; ; temporarily housed at ISI (IANA) . 3600000 NS L.ROOT-SERVERS.NET. L.ROOT-SERVERS.NET. 3600000 A 198.32.64.12 ; ; temporarily housed at ISI (IANA) . 3600000 NS M.ROOT-SERVERS.NET. M.ROOT-SERVERS.NET. 3600000 A 198.32.65.12 ; End of File |
