The named.conf file contains statements and comments. Statements end with a semicolon. Some statements can contain a contain a block of statements. Again, each statement in the block is terminated with a semicolon.
The named.conf file supports the following statements.
Table 5–4 named.conf Statements
Statement |
Description |
acl | Defines a named IP address match list used for access control. The address match list designates one or more IP addresses (dotted-decimal notation) or IP prefixes (dotted-decimal notation followed with a slash and the number of bits in the netmask). The named IP address match list must be defined by an acl statement before it can be used elsewhere; no forward references allowed. |
include | Inserts an include file at the point where the include statement is encountered. Use include to break up the configuration into more easily managed chunks. |
key | Specifies a key ID used for authentication and authorization on a particular name server. See the server statement. |
logging | Specifies the information the server logs and the destination of log messages. |
options | Controls global server configuration options and sets default values for other statements. |
server | Sets designated configuration options associated with a remote name server. Selectively applies options on a per-server basis, rather than to all servers. |
zone | Defines a zone. Selectively applies options on a per-zone basis, rather than to all zones. |
options { directory "/var/named"; datasize 2098; forward only; forwarders { 99.11.33.44; }; recursion no; transfers-in 10; transfers-per-ns 2; allow-transfer { 127.0.1.1/24; }; }; logging { category queries { default_syslog; }; }; include "/var/named/abcZones.conf" // here are the names of the master files zone "cities.zn" { type master; file "db.cities.zn"; }; zone "0.0.127.in-addr.arpa." { type master; file "db.127.cities.zn"; }; zone "168.192.in-addr.arpa" { type master; file "db.cities.zn.rev"; }; zone "sales.doc.com" { type slave; file "slave/db.sales.doc"; masters { 192.168.1.151; }; }; zone "168.192.in-addr.arpa" { type slave; file "slave/db.sales.doc.rev"; masters { 192.168.1.151; }; }; |
