Sun ONE Directory Server contains the following software components, which are installed by default when you install the entire Solaris disk suite.
Sun ONE Server Console
Sun ONE Server Console provides a common user interface for Sun ONE server products. From Sun ONE Server Console you can perform common server administration functions such as stopping and starting servers and installing new server instances. Sun ONE Server Console can be installed as a standalone application on any machine. You can also install it on your network and use it to manage remote servers.
Sun ONE Administration Server
Sun ONE Administration Server is a common server management module for Sun ONE servers. Administration Server receives communications from Sun ONE Server Console and passes those communications on to the appropriate Sun ONE server.
Sun ONE Directory Server is a high-performance, scalable LDAP server with an on-disk database. The Sun ONE Directory Server runs as the ns-slapd process on Solaris. This process is the server that manages the directory databases and responds to client requests. Sun ONE Directory Server is a required component.
