The following table lists the client attributes that can be set locally using ldapclient. See the ldapclient(1M) man page for more information.
Table 13–3 Local Client Attributes|
Attribute |
Description |
domainName |
Specifies the client's domain name (which becomes the default domain for the client machine). This attribute has no default value and must be specified. |
proxyDN |
The proxy's distinguished name. If the client machine is configured with credentialLevel of proxy, the proxyDN must be specified. |
proxyPassword |
The proxy's password. If the client machine is configured with credentialLevel of proxy, proxyPassword must be defined. |
certificatePath |
The directory on the local file system containing the certificate databases. If a client machine is configured with authenticationMethod or serviceAuthenticationMethod using TLS, then this attribute is used. The default value is /var/ldap. |
If the BaseDN in an SSD contains a trailing comma, it is treated as a relative value of the defaultSearchBase. The values of the defaultSearchBase are appended to the BaseDN before a search is performed.
