For large maps, LDAP virtual list view (VLV) indexes must be used to ensure LDAP searches return complete results. For information about setting up VLV indexes on the Sun ONE Directory Server, see the Sun ONE Directory Server documentation on the docs.sun.com web site.
VLV search results use a fixed page size of 50000. If VLVs are used with Sun ONE Directory Server, both the LDAP server and N2L server must be able to handle transfers of this size. If all of your maps are known to be smaller than this limit, you do not need to use VLV indexes. However, if your maps are larger than the size limit, or you are unsure of the size of all maps, use VLV indexes to avoid incomplete returns.
If you are using VLV indexes, set up the appropriate size limits as follows.
On the Sun ONE Directory Server: nsslapd-sizelimit attribute must be set greater than or equal to 50000 or -1. See the idsconfig(1M) man page.
On the N2L server: nisLDAPsearchSizelimit attribute must be set greater than or equal to 50000 or zero. For more information, see the NISLDAPmapping(4) man page.
Once VLV indexes have been created, activate them by running directoryserver with the vlvindex option on the Sun ONE Directory Server. See the directoryserver(1M) man page for more information.
Use the Sun ONE Directory Server idsconfig command to set up VLVs if the following conditions apply:
You are using the Sun ONE Directory Server.
You are mapping standard maps to RFC 2307 LDAP entries.
VLVs are domain specific, so each time idsconfig is run, VLVs are created for one NIS domain. Therefore, during the NIS–to–LDAP transition, you must run idsconfig once for each nisLDAPdomainContext attribute included in the NISLDAPmapping file.
You must manually create new Sun ONE Directory Server VLVs for maps, or copy and modify existing VLV indexes, if the following conditions apply:
You have large custom maps or have standard maps that are mapped to nonstandard DIT locations.
To view existing VLV indexes, type the following:
# ldapsearch -h hostname -s sub -b "cn=ldbm database,cn=plugins,cn=config" \ "objectClass=vlvSearch" |
