You can store NIS+ objects other than table entries in LDAP. However, doing so has no particular value unless you also have NIS+ replicas that obtain those NIS+ objects from LDAP. The recommended choices are the following.
There are no replicas, or the replicas obtain their data from the NIS+ master only.
Edit the mapping configuration file (see NIS+LDAPmapping(4)) to remove the following attribute values for all non-table-entry objects.
nisplusLDAPdatabaseIdMapping nisplusLDAPentryTtl nisplusLDAPobjectDN |
For example, if you started out from the /var/nis/NIS+LDAPmapping.template file, the sections you need to remove (or disable by commenting) are as follows.
# Standard NIS+ directories nisplusLDAPdatabaseIdMapping basedir: . . . |
nisplusLDAPdatabaseIdMapping user_attr_table:user_attr.org_dir |
nisplusLDAPdatabaseIdMapping audit_user_table:audit_user.org_dir # Standard NIS+ directories nisplusLDAPentryTtl basedir:21600:43200:43200 . . . |
nisplusLDAPentryTtl user_attr_table:21600:43200:43200 nisplusLDAPentryTtl audit_user_table:21600:43200:43200 # Standard NIS+ directories nisplusLDAPobjectDN basedir:cn=basedir,ou=nisPlus,?base?\ |
objectClass=nisplusObjectContainer:\ cn=basedir,ou=nisPlus,?base?\ objectClass=nisplusObjectContainer,\ objectClass=top . . . |
nisplusLDAPobjectDN audit_user_table:cn=audit_user,ou=nisPlus,?base?\ objectClass=nisplusObjectContainer:\ cn=audit_user,ou=nisPlus,?base?\ objectClass=nisplusObjectContainer,\ objectClass=top |
NIS+ replicas obtain their data from LDAP server.
Create the nisplusObject attribute and nisplusObjectContainer object class as shown in the following example (LDIF data is suitable for ldapadd(1). Attribute and object class OIDs are for illustration only.)
dn: cn=schema changetype: modify add: attributetypes attributetypes: ( 1.3.6.1.4.1.42.2.27.5.42.42.1.0 NAME 'nisplusObject' DESC 'An opaque representation of an NIS+ object' SYNTAX 1.3.6.1.4.1.1466.115.121.1.5 SINGLE-VALUE ) |
dn: cn=schema changetype: modify add: objectclasses |
objectclasses: (1.3.6.1.4.1.42.2.27.5.42.42.2.0 NAME'nisplusObjectContainer' |
SUP top STRUCTURAL DESC 'Abstraction of an NIS+ object' MUST ( cn $ nisplusObject ) ) |
You also need to create a container for the NIS+ objects. The following LDIF syntax shows how to create the ou=nisPlus,dc=some,dc=domain container, and can be used as input to ldapadd(1).
dn: ou=nisPlus,dc=some,dc=domain ou: nisPlus objectClass: top objectClass: organizationalUnit |
