System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Principal Names and Netnames
NIS+ authentication relies on principal names (a user or host name, qualified by the domain name) and netnames (the secure RPC equivalent of principal names) to uniquely identify an entity (principal) that can be authenticated. While RFC 2307 provides for storing the Diffie-Hellman keys used for NIS+ authentication, there is no specified place for the principal names or netnames.
The /var/nis/NIS+LDAPmapping.template file works around this problem by deriving the domain portion of principal and netnames from the owner name (itself a principal name) of the cred.org_dir table. Hence, if the NIS+ domain is x.y.z., and the owner of the cred.org_dir table is aaa.x.y.z., all principal names for NIS+ entries created from LDAP data will be of the following form.
user or system.x.y.z.
Netnames are of the following form.
unix.uid@x.y.z.
unix.nodename@x.y.z.
While this method of constructing principal and netnames probably is sufficient for most NIS+ installations, there are also some cases in which it fails, as shown in the following.
