This chapter covers the following topics.
Variable |
Definition for _______ Network |
Port number at which an instance of the directory server is installed (389) | |
Name of server | |
Replica server(s) (IP number:port number) | |
Directory manager [dn: cn=directory manager] | |
Domain name to be served | |
Maximum time (in seconds) to process client requests before timing out | |
Maximum number of entries returned for each search request |
Table 18–2 Client Profile Variable Definitions
Variable |
Definition for ________ Network |
Profile name | |
Server list (defaults to the local subnet) | |
Preferred server list (listed in order of which server to try first, second, and so on) | |
Search scope (number of levels down through the directory tree. 'One' or 'Sub') | |
Credential used to gain access to server. The default is anonymous | |
Follow Referrals? ( a pointer to another server if the main server is unavailable) The default is no. | |
Search time limit (in seconds, default 30) for waiting for server to return information. | |
Bind time limit (in seconds, default 30) for contacting server. The default is seconds. | |
Authentication method Default is none. |
Solaris 9 clients are compatible with directory servers set up to serve Solaris 9 clients. ldapclient(1M) can download such a profile and configure the client using version 1 profiles. To take advantage of new features built into Solaris 9 and to use the new security model, you must use version 2 profiles.
Servers can serve a mix of both old and new clients so that both clients see the same results from the server as long as schema mapping is not enabled and version 2 profiles are not configured to use special filters in serviceSearchDescriptors. Obviously if the server is not using the default schema, older clients cannot use that server as Solaris 9 clients cannot arbitrarily map their schema.
One additional change is that in Solaris naming clients, running ldap_cachemgr() was recommended, but optional. The ldap_cachemgr() must be running at all times. The daemon is required for the client to function properly.
By default, Solaris 9 uses a new schema for automount entries instead of using generic NIS map schema which Solaris 8 clients used. This means that if you set up a server with Solaris 9 tools, Solaris 8 clients cannot see the automount entries. For sites where the server being setup is to serve both Solaris 8 and Solaris 9 clients, a profile can be created to map the schema to the old one before adding automounter entries. This would ensure that ldapaddent(1M) adds the entries using the old schema. However, note that this would also mean that all Solaris 9 clients must use a profile where the schema for automount is mapped.
You need to add the following mapping attributes to your profile for this mapping to take effect.
attributeMap: automount:automountMapName=nisMapName attributeMap: automount:automountKey=cn attributeMap: automount:automountInformation=nisMapEntry objectclassMap: automount:automountMap=nisMap objectclassMap: automount:automount=nisObject |
There are two sets of LDAP-related commands in the Solaris operating environment. One set is the general LDAP tools, which do not require the client to be configured with LDAP naming services. The second set uses the common LDAP configuration on the client and therefore can only be used if the client is configured to use LDAP as its naming service.
LDAP command-line tools support a common set of options, including authentication and bind parameters.
These commands can be used to manipulate directory entries directly. The ldapsearch(1), ldapmodify(1), ldapadd(1), and ldapdelete(1) tools support a common text-based format for representing directory information called the LDAP Data Interchange Format (LDIF).
Tool |
Function |
Used to create entries in LDAP containers from the corresponding /etc files. This tool allows populating the directory from files. For example, it reads /etc/passwd format file and populates passwd entries in the directory. |
Used to list contents of various services from the directory. |
Used to set up Sun ONE Directory Server to serve LDAP naming service clients. |
# # Authentication management # # login service (explicit because of pam_dial_auth) # login auth required pam_authtok_get.so.1 login auth required pam_dhkeys.so.1 login auth required pam_dial_auth.so.1 login auth sufficient pam_unix_auth.so.1 login auth required pam_ldap.so.1 try_first_pass # # rlogin service (explicit because of pam_rhost_auth) # rlogin auth sufficient pam_rhosts_auth.so.1 rlogin auth required pam_authtok_get.so.1 rlogin auth required pam_dhkeys.so.1 rlogin auth sufficient pam_unix_auth.so.1 rlogin auth required pam_ldap.so.1 try_first_pass # # rsh service (explicit because of pam_rhost_auth) # rsh auth sufficient pam_rhosts_auth.so.1 rsh auth required pam_authtok_get.so.1 rsh auth required pam_dhkeys.so.1 rsh auth sufficient pam_unix_auth.so.1 rsh auth required pam_ldap.so.1 try_first_pass # # PPP service (explicit because of pam_dial_auth) # ppp auth required pam_authtok_get.so.1 ppp auth required pam_dhkeys.so.1 ppp auth required pam_dial_auth.so.1 ppp auth sufficient pam_unix_auth.so.1 ppp auth required pam_ldap.so.1 try_first_pass # # Default definitions for Authentication management # Used when service name is not explicitly mentioned for authentication # other auth required pam_authtok_get.so.1 other auth required pam_dhkeys.so.1 other auth sufficient pam_unix_auth.so.1 other auth required pam_ldap.so.1 try_first_pass # # passwd command (explicit because of a different authentication module) # passwd auth sufficient pam_passwd_auth.so.1 passwd auth required pam_ldap.so.1 try_first_pass # # cron service (explicit because of non-usage of pam_roles.so.1) # cron account required pam_projects.so.1 cron account required pam_unix_account.so.1 # # Default definition for Account management # Used when service name is not explicitly mentioned for account management # other account requisite pam_roles.so.1 other account required pam_projects.so.1 other account required pam_unix_account.so.1 # # Default definition for Session management # Used when service name is not explicitly mentioned for session management # other session required pam_unix_session.so.1 # # Default definition for Password management # Used when service name is not explicitly mentioned for password management # other password required pam_dhkeys.so.1 other password required pam_authtok_get.so.1 other password required pam_authtok_check.so.1 other password sufficient pam_authtok_store.so.1 other password required pam_ldap.so.1 # # Support for Kerberos V5 authentication (uncomment to use Kerberos) # #rlogin auth optional pam_krb5.so.1 try_first_pass #login auth optional pam_krb5.so.1 try_first_pass #other auth optional pam_krb5.so.1 try_first_pass #cron account optional pam_krb5.so.1 #other account optional pam_krb5.so.1 #other session optional pam_krb5.so.1 #other password optional pam_krb5.so.1 try_first_pass |
# PAM configuration # # Authentication management # # login service (explicit because of pam_dial_auth) # login auth requisite pam_authtok_get.so.1 login auth required pam_dhkeys.so.1 login auth required pam_dial_auth.so.1 login auth binding pam_unix_auth.so.1 server_policy login auth required pam_ldap.so.1 # # rlogin service (explicit because of pam_rhost_auth) # rlogin auth sufficient pam_rhosts_auth.so.1 rlogin auth requisite pam_authtok_get.so.1 rlogin auth required pam_dhkeys.so.1 rlogin auth binding pam_unix_auth.so.1 server_policy rlogin auth required pam_ldap.so.1 # # rsh service (explicit because of pam_rhost_auth, # and pam_unix_auth for meaningful pam_setcred) # rsh auth sufficient pam_rhosts_auth.so.1 rsh auth required pam_unix_auth.so.1 # # PPP service (explicit because of pam_dial_auth) # ppp auth requisite pam_authtok_get.so.1 ppp auth required pam_dhkeys.so.1 ppp auth required pam_dial_auth.so.1 ppp auth binding pam_unix_auth.so.1 server_policy ppp auth required pam_ldap.so.1 # # Default definitions for Authentication management # Used when service name is not explicitly mentioned for authentication # other auth requisite pam_authtok_get.so.1 other auth required pam_dhkeys.so.1 other auth binding pam_unix_auth.so.1 server_policy other auth required pam_ldap.so.1 # # passwd command (explicit because of a different authentication module) # passwd auth binding pam_passwd_auth.so.1 server_policy passwd auth required pam_ldap.so.1 # # cron service (explicit because of non-usage of pam_roles.so.1) # cron account required pam_projects.so.1 cron account required pam_unix_account.so.1 # # Default definition for Account management # Used when service name is not explicitly mentioned for account management # other account requisite pam_roles.so.1 other account required pam_projects.so.1 other account binding pam_unix_account.so.1 server_policy other account required pam_ldap.so.1 # # Default definition for Session management # Used when service name is not explicitly mentioned for session management # other session required pam_unix_session.so.1 # # Default definition for Password management # Used when service name is not explicitly mentioned for password management # other password required pam_dhkeys.so.1 other password requisite pam_authtok_get.so.1 other password requisite pam_authtok_check.so.1 other password required pam_authtok_store.so.1 server_policy # # Support for Kerberos V5 authentication (uncomment to use Kerberos) # #rlogin auth optional pam_krb5.so.1 try_first_pass #login auth optional pam_krb5.so.1 try_first_pass #other auth optional pam_krb5.so.1 try_first_pass #cron account optional pam_krb5.so.1 #other account optional pam_krb5.so.1 #other session optional pam_krb5.so.1 #other password optional pam_krb5.so.1 try_first_pass |
Schemas are definitions that describe what types of information can be stored as entries in a server's directory.
For a directory server to support Solaris LDAP naming clients, schemas defined in this chapter must be configured in the server unless schema is mapped using the schema mapping feature of the clients.
There are three required LDAP schemas defined by IETF: the RFC 2307 Network Information Service schema, the LDAP Mailgroups Internet draft, and the LDAP Internet Print Protocol (IPP) draft schema. To support the Naming Information Service, the definition of these schemas must be added to the directory server. The various RFCs can also be accessed on the IETF Web site http://www.ietf.org.
Internet drafts are draft documents valid for a maximum of six months and might be updated, or rendered obsolete, by other documents at any time.
The LDAP servers must be configured to support the revised RFC 2307.
The nisSchema OID is 1.3.6.1.1. The RFC 2307 attributes are the following.
( nisSchema.1.0 NAME 'uidNumber'
DESC 'An integer uniquely identifying a user in an
administrative domain'
EQUALITY integerMatch SYNTAX 'INTEGER' SINGLE-VALUE )
( nisSchema.1.1 NAME 'gidNumber'
DESC 'An integer uniquely identifying a group in an
( nisSchema.1.2 NAME 'gecos'
DESC 'The GECOS field; the common name'
EQUALITY caseIgnoreIA5Match
SUBSTRINGS caseIgnoreIA5SubstringsMatch
SYNTAX 'IA5String' SINGLE-VALUE )
( nisSchema.1.3 NAME 'homeDirectory'
DESC 'The absolute path to the home directory'
EQUALITY caseExactIA5Match
( nisSchema.1.4 NAME 'loginShell'
DESC 'The path to the login shell'
( nisSchema.1.5 NAME 'shadowLastChange'
( nisSchema.1.6 NAME 'shadowMin'
( nisSchema.1.7 NAME 'shadowMax'
( nisSchema.1.8 NAME 'shadowWarning'
( nisSchema.1.9 NAME 'shadowInactive'
( nisSchema.1.10 NAME 'shadowExpire'
( nisSchema.1.11 NAME 'shadowFlag'
( nisSchema.1.12 NAME 'memberUid'
SUBSTRINGS caseExactIA5SubstringsMatch
SYNTAX 'IA5String' )
( nisSchema.1.13 NAME 'memberNisNetgroup'
( nisSchema.1.14 NAME 'nisNetgroupTriple'
DESC 'Netgroup triple'
SYNTAX 'nisNetgroupTripleSyntax' )
( nisSchema.1.15 NAME 'ipServicePort'
( nisSchema.1.16 NAME 'ipServiceProtocol'
SUP name )
( nisSchema.1.17 NAME 'ipProtocolNumber'
( nisSchema.1.18 NAME 'oncRpcNumber'
( nisSchema.1.19 NAME 'ipHostNumber'
DESC 'IP address as a dotted decimal, eg. 192.168.1.1
omitting leading zeros'
SUP name )
( nisSchema.1.20 NAME 'ipNetworkNumber'
DESC 'IP network as a dotted decimal, eg. 192.168,
SUP name SINGLE-VALUE )
( nisSchema.1.21 NAME 'ipNetmaskNumber'
DESC 'IP netmask as a dotted decimal, eg. 255.255.255.0,
SYNTAX 'IA5String{128}' SINGLE-VALUE )
( nisSchema.1.22 NAME 'macAddress'
DESC 'MAC address in maximal, colon separated hex
notation, eg. 00:00:92:90:ee:e2'
SYNTAX 'IA5String{128}' )
( nisSchema.1.23 NAME 'bootParameter'
DESC 'rpc.bootparamd parameter'
SYNTAX 'bootParameterSyntax' )
( nisSchema.1.24 NAME 'bootFile'
DESC 'Boot image name'
( nisSchema.1.26 NAME 'nisMapName'
SUP name )
( nisSchema.1.27 NAME 'nisMapEntry'
SYNTAX 'IA5String{1024}' SINGLE-VALUE )
( nisSchema.1.28 NAME 'nisPublicKey'
DESC 'NIS public key'
SYNTAX 'nisPublicKeySyntax' )
( nisSchema.1.29 NAME 'nisSecretKey'
DESC 'NIS secret key'
SYNTAX 'nisSecretKeySyntax' )
( nisSchema.1.30 NAME 'nisDomain'
DESC 'NIS domain'
( nisSchema.1.31 NAME 'automountMapName'
DESC 'automount Map Name'
SUBSTR caseExactIA5SubstringsMatch
SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 SINGLE-VALUE )
( nisSchema.1.32 NAME 'automountKey'
DESC 'Automount Key value'
( nisSchema.1.33 NAME 'automountInformation'
DESC 'Automount information'
The nisSchema OID is 1.3.6.1.1. The RFC 2307 objectClasses are the following.
( nisSchema.2.0 NAME 'posixAccount' SUP top AUXILIARY
DESC 'Abstraction of an account with POSIX attributes'
MUST ( cn $ uid $ uidNumber $ gidNumber $ homeDirectory )
MAY ( userPassword $ loginShell $ gecos $ description ) )
( nisSchema.2.1 NAME 'shadowAccount' SUP top AUXILIARY
DESC 'Additional attributes for shadow passwords'
MUST uid
MAY ( userPassword $ shadowLastChange $ shadowMin
shadowMax $ shadowWarning $ shadowInactive $
shadowExpire $ shadowFlag $ description ) )
( nisSchema.2.2 NAME 'posixGroup' SUP top STRUCTURAL
DESC 'Abstraction of a group of accounts'
MUST ( cn $ gidNumber )
MAY ( userPassword $ memberUid $ description ) )
( nisSchema.2.3 NAME 'ipService' SUP top STRUCTURAL
DESC 'Abstraction an Internet Protocol service.
Maps an IP port and protocol (such as tcp or udp)
to one or more names; the distinguished value of
the cn attribute denotes the service's canonical
name'
MUST ( cn $ ipServicePort $ ipServiceProtocol )
MAY ( description ) )
( nisSchema.2.4 NAME 'ipProtocol' SUP top STRUCTURAL
DESC 'Abstraction of an IP protocol. Maps a protocol number
to one or more names. The distinguished value of the cn
attribute denotes the protocol's canonical name'
MUST ( cn $ ipProtocolNumber )
MAY description )
( nisSchema.2.5 NAME 'oncRpc' SUP top STRUCTURAL
DESC 'Abstraction of an Open Network Computing (ONC)
[RFC1057] Remote Procedure Call (RPC) binding.
This class maps an ONC RPC number to a name.
The distinguished value of the cn attribute denotes
the RPC service's canonical name'
MUST ( cn $ oncRpcNumber $ description )
MAY description )
( nisSchema.2.6 NAME 'ipHost' SUP top AUXILIARY
DESC 'Abstraction of a host, an IP device. The distinguished
value of the cn attribute denotes the host's canonical
name. Device SHOULD be used as a structural class'
MUST ( cn $ ipHostNumber )
MAY ( l $ description $ manager $ userPassword ) )
( nisSchema.2.7 NAME 'ipNetwork' SUP top STRUCTURAL
DESC 'Abstraction of a network. The distinguished value of
the cn attribute denotes the network's canonical name'
MUST ipNetworkNumber
MAY ( cn $ ipNetmaskNumber $ l $ description $ manager ) )
( nisSchema.2.8 NAME 'nisNetgroup' SUP top STRUCTURAL
DESC 'Abstraction of a netgroup. May refer to other netgroups'
MUST cn
MAY ( nisNetgroupTriple $ memberNisNetgroup $ description ) )
( nisSchema.2.9 NAME 'nisMap' SUP top STRUCTURAL
DESC 'A generic abstraction of a NIS map'
MUST nisMapName
MAY description )
( nisSchema.2.10 NAME 'nisObject' SUP top STRUCTURAL
DESC 'An entry in a NIS map'
MUST ( cn $ nisMapEntry $ nisMapName )
MAY description )
( nisSchema.2.11 NAME 'ieee802Device' SUP top AUXILIARY
DESC 'A device with a MAC address; device SHOULD be
MAY macAddress )
( nisSchema.2.12 NAME 'bootableDevice' SUP top AUXILIARY
DESC 'A device with boot parameters; device SHOULD be
MAY ( bootFile $ bootParameter ) )
( nisSchema.2.14 NAME 'nisKeyObject' SUP top AUXILIARY
DESC 'An object with a public and secret key'
MUST ( cn $ nisPublicKey $ nisSecretKey )
MAY ( uidNumber $ description ) )
( nisSchema.2.15 NAME 'nisDomainObject' SUP top AUXILIARY
DESC 'Associates a NIS domain with a naming context'
MUST nisDomain )
( nisSchema.2.16 NAME 'automountMap' SUP top STRUCTURAL
MUST ( automountMapName )
MAY description )
( nisSchema.2.17 NAME 'automount' SUP top STRUCTURAL
MUST ( automountKey $ automountInformation )
MAY description )
Mail alias information uses the schema defined by the LDAP Mailgroups Internet draft, formerly known as the draft-steinback-ldap-mailgroups draft. Until a new schema becomes available, Solaris LDAP clients will continue to use this schema for mail alias information.
The original LDAP Mailgroups schema contains a large number of attributes and object classes. Only two attributes and a single object class are used by Solaris clients. These are listed below.
The mail alias Attributes are the following.
( 0.9.2342.19200300.100.1.3 NAME 'mail' DESC 'RFC822 email address for this person' EQUALITY caseIgnoreIA5Match SYNTAX 'IA5String(256)' SINGLE-VALUE ) ( 2.16.840.1.113730.3.1.30 NAME 'mgrpRFC822MailMember' DESC 'RFC822 mail address of email only member of group' EQUALITY CaseIgnoreIA5Match SYNTAX 'IA5String(256)' ) |
The mail alias objectClass is the following.
( 2.16.840.1.113730.3.2.4 NAME 'mailGroup' SUP top STRUCTURAL MUST mail MAY ( cn $ mailAlternateAddress $ mailHost $ mailRequireAuth $ mgrpAddHeader $ mgrpAllowedBroadcaster $ mgrpAllowedDomain $ mgrpApprovePassword $ mgrpBroadcasterModeration $ mgrpDeliverTo $ mgrpErrorsTo $ mgrpModerator $ mgrpMsgMaxSize $ mgrpMsgRejectAction $ mgrpMsgRejectText $ mgrpNoMatchAddrs $ mgrpRemoveHeader $ mgrpRFC822MailMember )) |
The DUAConfSchemaOID is 1.3.6.1.4.1.11.1.3.1.
DESC 'Default LDAP server host address used by a DUA'
EQUALITY caseIgnoreMatch
SYNTAX 1.3.6.1.4.1.1466.115.121.1.15
SINGLE-VALUE )
( DUAConfSchemaOID.1.1 NAME 'defaultSearchBase'
DESC 'Default LDAP base DN used by a DUA'
EQUALITY distinguishedNameMatch
SYNTAX 1.3.6.1.4.1.1466.115.121.1.12
SINGLE-VALUE )
( DUAConfSchemaOID.1.2 NAME 'preferredServerList'
DESC 'Preferred LDAP server host addresses to be used by a
DUA'
SINGLE-VALUE )
( DUAConfSchemaOID.1.3 NAME 'searchTimeLimit'
DESC 'Maximum time in seconds a DUA should allow for a
search to complete'
SYNTAX 1.3.6.1.4.1.1466.115.121.1.27
SINGLE-VALUE )
( DUAConfSchemaOID.1.4 NAME 'bindTimeLimit'
DESC 'Maximum time in seconds a DUA should allow for the
bind operation to complete'
SINGLE-VALUE )
( DUAConfSchemaOID.1.5 NAME 'followReferrals'
DESC 'Tells DUA if it should follow referrals
returned by a DSA search result'
SYNTAX 1.3.6.1.4.1.1466.115.121.1.7
SINGLE-VALUE )
( DUAConfSchemaOID.1.6 NAME 'authenticationMethod'
DESC 'A keystring which identifies the type of
authentication method used to contact the DSA'
SINGLE-VALUE )
( DUAConfSchemaOID.1.7 NAME 'profileTTL'
DESC 'Time to live, in seconds, before a client DUA
should re-read this configuration profile'
'serviceSearchDescriptor'
DESC 'LDAP search descriptor list used by a DUA'
EQUALITY caseExactMatch
SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 )
( DUAConfSchemaOID.1.9 NAME 'attributeMap'
DESC 'Attribute mappings used by a DUA'
SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 )
( DUAConfSchemaOID.1.10 NAME 'credentialLevel'
DESC 'Identifies type of credentials a DUA should
use when binding to the LDAP server'
SINGLE-VALUE )
( DUAConfSchemaOID.1.11 NAME 'objectclassMap'
DESC 'Objectclass mappings used by a DUA'
( DUAConfSchemaOID.1.12 NAME 'defaultSearchScope' SINGLE-VALUE )
( DUAConfSchemaOID.1.13 NAME 'serviceCredentialLevel'
should use when binding to the LDAP server for a
specific service'
( DUAConfSchemaOID.1.15 NAME 'serviceAuthenticationMethod'
DESC 'Authentication Method used by a service of the DUA'
( DUAConfSchemaOID.2.4 NAME 'DUAConfigProfile'
SUP top STRUCTURAL
DESC 'Abstraction of a base configuration for a DUA'
MUST ( cn )
MAY ( defaultServerList $ preferredServerList $
defaultSearchBase $ defaultSearchScope $
searchTimeLimit $ bindTimeLimit $
credentialLevel $ authenticationMethod $
followReferrals $ serviceSearchDescriptor $
serviceCredentialLevel $ serviceAuthenticationMethod $
objectclassMap $ attributeMap $
profileTTL ) )
The schemas required for the Solaris operating environment are the following.
Solaris Projects schema
Role-based access control and execution profile schemas
Printer schemas
/etc/project is a local source of attributes associated with projects. For more information, see project(4).
The Project Attributes are the following.
( 1.3.6.1.4.1.42.2.27.5.1.1 NAME 'SolarisProjectID' DESC 'Unique ID for a Solaris Project entry' EQUALITY integerMatch SYNTAX INTEGER SINGLE ) ( 1.3.6.1.4.1.42.2.27.5.1.2 NAME 'SolarisProjectName' DESC 'Name of a Solaris Project entry' EQUALITY caseExactIA5Match SYNTAX IA5String SINGLE ) ( 1.3.6.1.4.1.42.2.27.5.1.3 NAME 'SolarisProjectAttr' DESC 'Attributes of a Solaris Project entry' EQUALITY caseExactIA5Match SYNTAX IA5String ) ( 1.3.6.1.4.1.42.2.27.5.1.30 NAME 'memberGid' DESC 'Posix Group Name' EQUALITY caseExactIA5Match SYNTAX 'IA5String' ) |
The Project objectClass is the following.
( 1.3.6.1.4.1.42.2.27.5.2.1 NAME 'SolarisProject' SUP top STRUCTURAL MUST ( SolarisProjectID $ SolarisProjectName ) MAY ( memberUid $ memberGid $ description $ SolarisProjectAttr ) ) |
/etc/user_attr is a local source of extended attributes associated with users and roles. For more information, see user_attr(4).
The role-based access control Attributes are the following.
( 1.3.6.1.4.1.42.2.27.5.1.4 NAME 'SolarisAttrKeyValue' DESC 'Semi-colon separated key=value pairs of attributes' EQUALITY caseIgnoreIA5Match SUBSTRINGS caseIgnoreIA5Match SYNTAX 'IA5String' SINGLE-VALUE ) ( 1.3.6.1.4.1.42.2.27.5.1.7 NAME 'SolarisAttrShortDesc' DESC 'Short description about an entry, used by GUIs' EQUALITY caseIgnoreIA5Match SYNTAX 'IA5String' SINGLE-VALUE ) ( 1.3.6.1.4.1.42.2.27.5.1.8 NAME 'SolarisAttrLongDesc' DESC 'Detail description about an entry' EQUALITY caseIgnoreIA5Match SYNTAX 'IA5String' SINGLE-VALUE ) ( 1.3.6.1.4.1.42.2.27.5.1.9 NAME 'SolarisKernelSecurityPolicy' DESC 'Solaris kernel security policy' EQUALITY caseIgnoreIA5Match SYNTAX 'IA5String' SINGLE-VALUE ) ( 1.3.6.1.4.1.42.2.27.5.1.10 NAME 'SolarisProfileType' DESC 'Type of object defined in profile' EQUALITY caseIgnoreIA5Match SYNTAX 'IA5String' SINGLE-VALUE ) ( 1.3.6.1.4.1.42.2.27.5.1.11 NAME 'SolarisProfileId' DESC 'Identifier of object defined in profile' EQUALITY caseExactIA5Match SYNTAX 'IA5String' SINGLE-VALUE ) ( 1.3.6.1.4.1.42.2.27.5.1.12 NAME 'SolarisUserQualifier' DESC 'Per-user login attributes' EQUALITY caseIgnoreIA5Match SYNTAX 'IA5String' SINGLE-VALUE ) ( 1.3.6.1.4.1.42.2.27.5.1.13 NAME 'SolarisReserved1' DESC 'Reserved for future use' EQUALITY caseIgnoreIA5Match SYNTAX 'IA5String' SINGLE-VALUE ) ( 1.3.6.1.4.1.42.2.27.5.1.14 NAME 'SolarisReserved2' DESC 'Reserved for future use' EQUALITY caseIgnoreIA5Match SYNTAX 'IA5String' SINGLE-VALUE ) |
The role based access control objectClassses are the following.
( 1.3.6.1.4.1.42.2.27.5.2.3 NAME 'SolarisUserAttr' SUP top AUXILIARY
DESC 'User attributes'
MAY ( SolarisUserQualifier $ SolarisAttrReserved1 $ \
SolarisAttrReserved2 $ SolarisAttrKeyValue ) )
( 1.3.6.1.4.1.42.2.27.5.2.4 NAME 'SolarisAuthAttr' SUP top STRUCTURAL
DESC 'Authorizations data'
MUST cn
MAY ( SolarisAttrReserved1 $ SolarisAttrReserved2 $ \
SolarisAttrShortDesc $ SolarisAttrLongDesc $ \
( 1.3.6.1.4.1.42.2.27.5.2.5 NAME 'SolarisProfAttr' SUP top STRUCTURAL
DESC 'Profiles data'
MUST cn
SolarisAttrLongDesc $ SolarisAttrKeyValue ) )
( 1.3.6.1.4.1.42.2.27.5.2.6 NAME 'SolarisExecAttr' SUP top AUXILIARY
DESC 'Profiles execution attributes'
MAY ( SolarisKernelSecurityPolicy $ SolarisProfileType $ \
SolarisProfileId $ SolarisAttrKeyValue ) )
The following sections provide information about the attributes and ObjectClasses for the internet print protocol and the Sun printer.
( 1.3.18.0.2.4.1140 NAME 'printer-uri' DESC 'A URI supported by this printer. This URI SHOULD be used as a relative distinguished name (RDN). If printer-xri-supported is implemented, then this URI value MUST be listed in a member value of printer-xri-supported.' EQUALITY caseIgnoreMatch ORDERING caseIgnoreOrderingMatch SUBSTR caseIgnoreSubstringsMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 SINGLE-VALUE ) |
( 1.3.18.0.2.4.1107 NAME 'printer-xri-supported' DESC 'The unordered list of XRI (extended resource identifiers) supported by this printer. Each member of the list consists of a URI (uniform resource identifier) followed by optional authentication and security metaparameters.' EQUALITY caseIgnoreMatch ORDERING caseIgnoreOrderingMatch SUBSTR caseIgnoreSubstringsMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 ) |
( 1.3.18.0.2.4.1135
NAME 'printer-name'
DESC 'The site-specific administrative name of this printer, more end-user
friendly than a URI.'
SYNTAX 1.3.6.1.4.1.1466.115.121.1.15{127} SINGLE-VALUE )
( 1.3.18.0.2.4.1119
NAME 'printer-natural-language-configured'
DESC 'The configured language in which error and status messages will be
generated (by default) by this printer.
Also, a possible language for printer string attributes set by operator,
system administrator, or manufacturer.
Also, the (declared) language of the "printer-name", "printer-location",
"printer-info", and "printer-make-and-model" attributes of this printer.
For example: "en-us" (US English) or "fr-fr" (French in France) Legal values of
language tags conform to [RFC3066] "Tags for the Identification of Languages".'
( 1.3.18.0.2.4.1136
NAME 'printer-location'
DESC 'Identifies the location of the printer. This could include
things like: "in Room 123A", "second floor of building XYZ".'
( 1.3.18.0.2.4.1139
NAME 'printer-info'
DESC 'Identifies the descriptive information about this printer.
This could include things like: "This printer can be used for
printing color transparencies for HR presentations", or
"Out of courtesy for others, please print only small (1-5 page)
jobs at this printer", or even "This printer is going away on July 1, 1997,
please find a new printer".'
SUBSTR caseIgnoreSubstringsMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.15{127}
SINGLE-VALUE )
( 1.3.18.0.2.4.1134 NAME 'printer-more-info' DESC 'A URI used to obtain more information about this specific printer. For example, this could be an HTTP type URI referencing an HTML page accessible to a Web Browser. The information obtained from this URI is intended for end user consumption.' EQUALITY caseIgnoreMatch ORDERING caseIgnoreOrderingMatch SUBSTR caseIgnoreSubstringsMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 SINGLE-VALUE ) |
( 1.3.18.0.2.4.1138
NAME 'printer-make-and-model'
DESC 'Identifies the make and model of the device.
The device manufacturer MAY initially populate this attribute.'
( 1.3.18.0.2.4.1133
NAME 'printer-ipp-versions-supported'
DESC 'Identifies the IPP protocol version(s) that this printer supports,
including major and minor versions,
i.e., the version numbers for which this Printer implementation meets
the conformance requirements.'
SUBSTR caseIgnoreSubstringsMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.15{127} )
( 1.3.18.0.2.4.1132 NAME 'printer-multiple-document-jobs-supported' DESC 'Indicates whether or not the printer supports more than one document per job, i.e., more than one Send-Document or Send-Data operation with document data.' EQUALITY booleanMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.7 SINGLE-VALUE ) |
( 1.3.18.0.2.4.1109
NAME 'printer-charset-configured'
DESC 'The configured charset in which error and status messages will be
Also, a possible charset for printer string attributes set by operator,
For example: "utf-8" (ISO 10646/Unicode) or "iso-8859-1" (Latin1).
Legal values are defined by the IANA Registry of Coded Character Sets and
the "(preferred MIME name)" SHALL be used as the tag.
For coherence with IPP Model, charset tags in this attribute SHALL be
lowercase normalized.
This attribute SHOULD be static (time of registration) and SHOULD NOT be
dynamically refreshed attributetypes: (subsequently).'
SYNTAX 1.3.6.1.4.1.1466.115.121.1.15{63} SINGLE-VALUE )
( 1.3.18.0.2.4.1131
NAME 'printer-charset-supported'
DESC 'Identifies the set of charsets supported for attribute type values of
type Directory String for this directory entry.
the preferred MIME name.'
SYNTAX 1.3.6.1.4.1.1466.115.121.1.15{63} )
( 1.3.18.0.2.4.1137
NAME 'printer-generated-natural-language-supported'
DESC 'Identifies the natural language(s) supported for this directory entry.
For example: "en-us" (US English) or "fr-fr" (French in France).
Legal values conform to [RFC3066], Tags for the Identification of Languages.'
( 1.3.18.0.2.4.1130
NAME 'printer-document-format-supported'
DESC 'The possible document formats in which data may be interpreted
and printed by this printer.
Legal values are MIME types come from the IANA Registry of Internet Media Types.'
( 1.3.18.0.2.4.1129 NAME 'printer-color-supported' DESC 'Indicates whether this printer is capable of any type of color printing at all, including highlight color.' EQUALITY booleanMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.7 SINGLE-VALUE ) |
( 1.3.18.0.2.4.1128
NAME 'printer-compression-supported'
DESC 'Compression algorithms supported by this printer.
For example: "deflate, gzip". Legal values include; "none", "deflate"
attributetypes: (public domain ZIP), "gzip" (GNU ZIP), "compress" (UNIX).'
SYNTAX 1.3.6.1.4.1.1466.115.121.1.15{255} )
( 1.3.18.0.2.4.1127 NAME 'printer-pages-per-minute' DESC 'The nominal number of pages per minute which may be output by this printer (e.g., a simplex or black-and-white printer). This attribute is informative, NOT a service guarantee. Typically, it is the value used in marketing literature to describe this printer.' EQUALITY integerMatch ORDERING integerOrderingMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 SINGLE-VALUE ) |
( 1.3.18.0.2.4.1126 NAME 'printer-pages-per-minute-color' DESC 'The nominal number of color pages per minute which may be output by this printer (e.g., a simplex or color printer). This attribute is informative, NOT a service guarantee. Typically, it is the value used in marketing literature to describe this printer.' EQUALITY integerMatch ORDERING integerOrderingMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 SINGLE-VALUE ) |
( 1.3.18.0.2.4.1125 NAME 'printer-finishings-supported'
DESC 'The possible finishing operations supported by this printer.
Legal values include; "none", "staple", "punch", "cover", "bind", "saddle-stitch",
"edge-stitch", "staple-top-left", "staple-bottom-left", "staple-top-right",
"staple-bottom-right", "edge-stitch-left", "edge-stitch-top", "edge-stitch-right",
"edge-stitch-bottom", "staple-dual-left", "staple-dual-top", "staple-dual-right",
"staple-dual-bottom".'
( 1.3.18.0.2.4.1124 NAME 'printer-number-up-supported' DESC 'The possible numbers of print-stream pages to impose upon a single side of an instance of a selected medium. Legal values include; 1, 2, and 4. Implementations may support other values.' EQUALITY integerMatch ORDERING integerOrderingMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 ) |
( 1.3.18.0.2.4.1123 NAME 'printer-sides-supported'
DESC 'The number of impression sides (one or two) and the two-sided impression
rotations supported by this printer.
Legal values include; "one-sided", "two-sided-long-edge", "two-sided-short-edge".'
( 1.3.18.0.2.4.1122 NAME 'printer-media-supported'
DESC 'The standard names/types/sizes (and optional color suffixes) of the media
For example: "iso-a4", "envelope", or "na-letter-white".
Legal values conform to ISO 10175, Document Printing Application (DPA), and any
IANA registered extensions.'
( 1.3.18.0.2.4.1117 NAME 'printer-media-local-supported'
DESC 'Site-specific names of media supported by this printer, in the language in
"printer-natural-language-configured".
For example: "purchasing-form" (site-specific name) as opposed to
(in "printer-media-supported"): "na-letter" (standard keyword from ISO 10175).'
EQUALITY caseIgnoreMatch SUBSTR caseIgnoreSubstringsMatch
( 1.3.18.0.2.4.1121 NAME 'printer-resolution-supported'
DESC 'List of resolutions supported for printing documents by this printer.
Each resolution value is a string with 3 fields:
1) Cross feed direction resolution (positive integer), 2) Feed direction
resolution (positive integer), 3) Resolution unit.
Legal values are "dpi" (dots per inch) and "dpcm" (dots per centimeter).
Each resolution field is delimited by ">". For example: "300> 300> dpi>".'
( 1.3.18.0.2.4.1120 NAME 'printer-print-quality-supported'
DESC 'List of print qualities supported for printing documents on this printer.
For example: "draft, normal". Legal values include; "unknown", "draft", "normal",
"high".'
( 1.3.18.0.2.4.1110 NAME 'printer-job-priority-supported' DESC 'Indicates the number of job priority levels supported. An IPP conformant printer which supports job priority must always support a full range of priorities from "1" to "100" (to ensure consistent behavior), therefore this attribute describes the "granularity". Legal values of this attribute are from "1" to "100".' EQUALITY integerMatch ORDERING integerOrderingMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 SINGLE-VALUE ) |
( 1.3.18.0.2.4.1118 NAME 'printer-copies-supported' DESC 'The maximum number of copies of a document that may be printed as a single job. A value of "0" indicates no maximum limit. A value of "-1" indicates unknown.' EQUALITY integerMatch ORDERING integerOrderingMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 SINGLE-VALUE ) |
( 1.3.18.0.2.4.1111 NAME 'printer-job-k-octets-supported' DESC 'The maximum size in kilobytes (1,024 octets actually) incoming print job that this printer will accept. A value of "0" indicates no maximum limit. A value of "-1" indicates unknown.' EQUALITY integerMatch ORDERING integerOrderingMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 SINGLE-VALUE ) |
( 1.3.18.0.2.4.1113
NAME 'printer-service-person'
DESC 'The name of the current human service person responsible for servicing this
printer.
It is suggested that this string include information that would enable other humans
to reach the service person, such as a phone number.'
SINGLE-VALUE )
( 1.3.18.0.2.4.1114
NAME 'printer-delivery-orientation-supported'
DESC 'The possible delivery orientations of pages as they are printed and ejected
from this printer.
Legal values include; "unknown", "face-up", and "face-down".'
( 1.3.18.0.2.4.1115
NAME 'printer-stacking-order-supported'
DESC 'The possible stacking order of pages as they are printed and ejected from
this printer.
Legal values include; "unknown", "first-to-last", "last-to-first".'
( 1.3.18.0.2.4.1116
NAME 'printer-output-features-supported'
DESC 'The possible output features supported by this printer.
Legal values include; "unknown", "bursting", "decollating", "page-collating",
"offset-stacking".'
( 1.3.18.0.2.4.1108
NAME 'printer-aliases'
DESC 'Site-specific administrative names of this printer in addition the printer
name specified for printer-name.'
( 1.3.6.1.4.1.42.2.27.5.1.63 NAME 'sun-printer-bsdaddr' DESC 'Sets the server, print queue destination name and whether the client generates protocol extensions. "Solaris" specifies a Solaris print server extension. The value is represented b the following value: server "," destination ", Solaris".' SYNTAX '1.3.6.1.4.1.1466.115.121.1.15' SINGLE-VALUE ) |
( 1.3.6.1.4.1.42.2.27.5.1.64 NAME 'sun-printer-kvp' DESC 'This attribute contains a set of key value pairs which may have meaning to the print subsystem or may be user defined. Each value is represented by the following: key "=" value.' SYNTAX '1.3.6.1.4.1.1466.115.121.1.15' ) |
objectclasses: ( 1.3.18.0.2.6.2549 NAME 'slpService' DESC 'DUMMY definition' SUP 'top' MUST (objectclass) MAY ()) |
objectclasses: ( 1.3.18.0.2.6.254 NAME 'slpServicePrinter' DESC 'Service Location Protocol (SLP) information.' AUXILIARY SUP 'slpService') |
objectclasses: ( 1.3.18.0.2.6.258 NAME 'printerAbstract' DESC 'Printer related information.' ABSTRACT SUP 'top' MAY ( printer-name $ printer-natural-language-configured $ printer-location $ printer-info $ printer-more-info $ printer-make-and-model $ printer-multiple-document-jobs-supported $ printer-charset-configured $ printer-charset-supported $ printer-generated-natural-language-supported $ printer-document-format-supported $ printer-color-supported $ printer-compression-supported $ printer-pages-per-minute $ printer-pages-per-minute-color $ printer-finishings-supported $ printer-number-up-supported $ printer-sides-supported $ printer-media-supported $ printer-media-local-supported $ printer-resolution-supported $ printer-print-quality-supported $ printer-job-priority-supported $ printer-copies-supported $ printer-job-k-octets-supported $ printer-current-operator $ printer-service-person $ printer-delivery-orientation-supported $ printer-stacking-order-supported $ printer! -output-features-supported )) |
objectclasses: ( 1.3.18.0.2.6.255 NAME 'printerService' DESC 'Printer information.' STRUCTURAL SUP 'printerAbstract' MAY ( printer-uri $ printer-xri-supported )) |
objectclasses: ( 1.3.18.0.2.6.257 NAME 'printerServiceAuxClass' DESC 'Printer information.' AUXILIARY SUP 'printerAbstract' MAY ( printer-uri $ printer-xri-supported )) |
objectclasses: ( 1.3.18.0.2.6.256 NAME 'printerIPP' DESC 'Internet Printing Protocol (IPP) information.' AUXILIARY SUP 'top' MAY ( printer-ipp-versions-supported $ printer-multiple-document-jobs-supported )) |
objectclasses: ( 1.3.18.0.2.6.253 NAME 'printerLPR' DESC 'LPR information.' AUXILIARY SUP 'top' MUST ( printer-name ) MAY ( printer-aliases)) |
objectclasses: ( 1.3.6.1.4.1.42.2.27.5.2.14 NAME 'sunPrinter' DESC 'Sun printer information' SUP 'top' AUXILIARY MUST (objectclass $ printer-name) MAY (sun-printer-bsdaddr $ sun-printer-kvp)) |
ATTRIBUTE ( 1.3.6.1.4.1.42.2.27.5.1.63
NAME sun-printer-bsdaddr
Solaris print server extension. The value is represented by
SINGLE-VALUE
ATTRIBUTE ( 1.3.6.1.4.1.42.2.27.5.1.64
NAME sun-printer-kvp
OBJECTCLASS ( 1.3.6.1.4.1.42.2.27.5.2.14 NAME sunPrinter DESC 'Sun printer information' SUP top AUXILIARY MUST ( printer-name ) MAY ( sun-printer-bsdaddr $ sun-printer-kvp )) |
To support Solaris 9 LDAP clients, the server, regardless of what brand, must support the LDAP v3 protocol and compound naming and auxiliary object classes. In addition, at least one of the following controls must be supported.
Simple paged-mode (RFC 2696)
Virtual List View controls
The server must support at least one of the following authentication methods.
If using pam_unix, the server must support storing passwords in UNIX crypt format.
If using TLS, the server must support SSL or TLS.
If you do not manually specify a parameter for a given service using an SSD, the default filter is used. To list the default filters for a given service, use ldaplist with the —v option.
In the following example, filter=(&(objectclass=iphost)(cn=abcde)defines the default filters.
database=hosts filter=(&(objectclass=iphost)(cn=abcde) user data=(&(%s) (cn=abcde)) |
ldaplist generates the following list of default filters, where %s signifies a string and %d, a number.
hosts (&(objectclass=iphost)(cn=%s)) -------------- passwd (&(objectclass=posixaccount)(uid=%s)) -------------- services (&(objectclass=ipservice)(cn=%s)) -------------- group (&(objectclass=posixgroup)(cn=%s)) -------------- netgroup (&(objectclass=nisnetgroup)(cn=%s)) -------------- networks (&(objectclass=ipnetwork)(ipnetworknumber=%s)) -------------- netmasks (&(objectclass=ipnetwork)(ipnetworknumber=%s)) -------------- rpc (&(objectclass=oncrpc)(cn=%s)) -------------- protocols (&(objectclass=ipprotocol)(cn=%s)) -------------- bootparams (&(objectclass=bootableDevice)(cn=%s)) -------------- ethers (&(objectclass=ieee802Device)(cn=%s)) -------------- publickey (&(objectclass=niskeyobject)(cn=%s)) or (&(objectclass=niskeyobject)(uidnumber=%d)) -------------- aliases (&(objectclass=mailGroup)(cn=%s)) -------------- |
Filter |
Definition |
bootparamByName |
(&(objectClass=bootableDevice)(cn=%s)) |
etherByHost |
(&(objectClass=ieee802Device)(cn=%s)) |
etherByEther |
(&(objectClass=ieee802Device)(macAddress=%s)) |
groupByName |
(&(objectClass=posixGroup)(cn=%s)) |
groupByGID |
(&(objectClass=posixGroup)(gidNumber=%ld)) |
groupByMember |
(&(objectClass=posixGroup)(memberUid=%s)) |
hostsByName |
(&(objectClass=ipHost)(cn=%s)) |
hostsByAddr |
(&(objectClass=ipHost)(ipHostNumber=%s)) |
keyByUID |
(&(objectClass=nisKeyObject)(uidNumber=%s)) |
keyByHost |
(&(objectClass=nisKeyObject)(cn=%s)) |
netByName |
(&(objectClass=ipNetwork)(cn=%s)) |
netByAddr |
(&(objectClass=ipNetwork)(ipNetworkNumber=%s)) |
nisgroupMember |
(membernisnetgroup=%s) |
maskByNet |
printerByName |
(&(objectClass=sunPrinter)(printer-name=%s)) |
projectByName |
(&(objectClass=SolarisProject)(SolarisProjectName=%s)) |
projectByID |
(&(objectClass=SolarisProject)(SolarisProjectID=%ld)) |
protoByName |
(&(objectClass=ipProtocol)(cn=%s)) |
protoByNumber |
(&(objectClass=ipProtocol)(ipProtocolNumber=%d)) |
passwordByName |
(&(objectClass=posixAccount)(uid=%s)) |
passwordByNumber |
(&(objectClass=posixAccount)(uidNumber=%ld)) |
rpcByName |
(&(objectClass=oncRpc)(cn=%s)) |
rpcByNumber |
(&(objectClass=oncRpc)(oncRpcNumber=%d)) |
serverByName |
(&(objectClass=ipService)(cn=%s)) |
serverByPort |
(&(objectClass=ipService)(ipServicePort=%ld)) |
serverByNameAndProto |
(&(objectClass=ipService)(cn=%s)(ipServiceProtocol=%s)) |
specialByNameserver |
ByPortAndProto |
(&(objectClass=shadowAccount)(uid=%s)) |
netgroupByTriple |
(&(objectClass=nisNetGroup)(nisnetgrouptriple=(%s,%s,%s))) |
netgroupByMember |
(&(objectClass=nisNetGroup)(|(membernisnetgroup=%s) |
authName |
(&(objectClass=SolarisAuthAttr)(cn=%s)) |
auditUserByName |
(&(objectClass=SolarisAuditUser)(uid=%s)) |
execByName |
(&(objectClass=SolarisExecAttr)(cn=%s) (SolarisKernelSecurityPolicy=%s)(SolarisProfileType=%s)) |
execByPolicy |
(&(objectClass=SolarisExecAttr)(SolarisProfileId=%s) (SolarisKernelSecurityPolicy=%s)(SolarisProfileType=%s)) |
profileByName |
(&(objectClass=SolarisProfAttr)(cn=%s)) |
userByName |
(&(objectClass=SolarisUserAttr)(uid=%s)) |
The following table lists the getent attribute filters.
Table 18–5 getent Attribute Filters|
Filter |
Definition |
aliases |
(objectClass=rfc822MailGroup) |
auth_attr |
(objectClass=SolarisAuthAttr) |
audit_user |
(objectClass=SolarisAuditUser) |
exec_attr |
(objectClass=SolarisExecAttr) |
group |
(objectClass=posixGroup) |
hosts |
(objectClass=ipHost) |
networks |
(objectClass=ipNetwork) |
prof_attr |
(objectClass=SolarisProfAttr) |
protocols |
(objectClass=ipProtocol) |
passwd |
(objectClass=posixAccount) |
printers |
(objectClass=sunPrinter) |
rpc |
(objectClass=oncRpc) |
services |
(objectClass=ipService) |
shadow |
(objectclass=shadowAccount) |
project |
(objectClass=SolarisProject) |
usr_attr |
(objectClass=SolarisUserAttr) |
