The DUAConfSchemaOID is 1.3.6.1.4.1.11.1.3.1.
DESC 'Default LDAP server host address used by a DUA'
EQUALITY caseIgnoreMatch
SYNTAX 1.3.6.1.4.1.1466.115.121.1.15
SINGLE-VALUE )
( DUAConfSchemaOID.1.1 NAME 'defaultSearchBase'
DESC 'Default LDAP base DN used by a DUA'
EQUALITY distinguishedNameMatch
SYNTAX 1.3.6.1.4.1.1466.115.121.1.12
SINGLE-VALUE )
( DUAConfSchemaOID.1.2 NAME 'preferredServerList'
DESC 'Preferred LDAP server host addresses to be used by a
DUA'
SINGLE-VALUE )
( DUAConfSchemaOID.1.3 NAME 'searchTimeLimit'
DESC 'Maximum time in seconds a DUA should allow for a
search to complete'
EQUALITY integerMatch
SYNTAX 1.3.6.1.4.1.1466.115.121.1.27
SINGLE-VALUE )
( DUAConfSchemaOID.1.4 NAME 'bindTimeLimit'
DESC 'Maximum time in seconds a DUA should allow for the
bind operation to complete'
SINGLE-VALUE )
( DUAConfSchemaOID.1.5 NAME 'followReferrals'
DESC 'Tells DUA if it should follow referrals
returned by a DSA search result'
EQUALITY caseIgnoreIA5Match
SYNTAX 1.3.6.1.4.1.1466.115.121.1.7
SINGLE-VALUE )
( DUAConfSchemaOID.1.6 NAME 'authenticationMethod'
DESC 'A keystring which identifies the type of
authentication method used to contact the DSA'
SINGLE-VALUE )
( DUAConfSchemaOID.1.7 NAME 'profileTTL'
DESC 'Time to live, in seconds, before a client DUA
should re-read this configuration profile'
'serviceSearchDescriptor'
DESC 'LDAP search descriptor list used by a DUA'
EQUALITY caseExactMatch
SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 )
( DUAConfSchemaOID.1.9 NAME 'attributeMap'
DESC 'Attribute mappings used by a DUA'
SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 )
( DUAConfSchemaOID.1.10 NAME 'credentialLevel'
DESC 'Identifies type of credentials a DUA should
use when binding to the LDAP server'
SINGLE-VALUE )
( DUAConfSchemaOID.1.11 NAME 'objectclassMap'
DESC 'Objectclass mappings used by a DUA'
( DUAConfSchemaOID.1.12 NAME 'defaultSearchScope' SINGLE-VALUE )
( DUAConfSchemaOID.1.13 NAME 'serviceCredentialLevel'
should use when binding to the LDAP server for a
specific service'
( DUAConfSchemaOID.1.15 NAME 'serviceAuthenticationMethod'
DESC 'Authentication Method used by a service of the DUA'
( DUAConfSchemaOID.2.4 NAME 'DUAConfigProfile'
SUP top STRUCTURAL
DESC 'Abstraction of a base configuration for a DUA'
MUST ( cn )
MAY ( defaultServerList $ preferredServerList $
defaultSearchBase $ defaultSearchScope $
searchTimeLimit $ bindTimeLimit $
credentialLevel $ authenticationMethod $
followReferrals $ serviceSearchDescriptor $
serviceCredentialLevel $ serviceAuthenticationMethod $
objectclassMap $ attributeMap $
profileTTL ) )
