Variable |
Definition for _______ Network |
Port number at which an instance of the directory server is installed (389) | |
Name of server | |
Replica server(s) (IP number:port number) | |
Directory manager [dn: cn=directory manager] | |
Domain name to be served | |
Maximum time (in seconds) to process client requests before timing out | |
Maximum number of entries returned for each search request |
Table 18–2 Client Profile Variable Definitions
Variable |
Definition for ________ Network |
Profile name | |
Server list (defaults to the local subnet) | |
Preferred server list (listed in order of which server to try first, second, and so on) | |
Search scope (number of levels down through the directory tree. 'One' or 'Sub') | |
Credential used to gain access to server. The default is anonymous | |
Follow Referrals? ( a pointer to another server if the main server is unavailable) The default is no. | |
Search time limit (in seconds, default 30) for waiting for server to return information. | |
Bind time limit (in seconds, default 30) for contacting server. The default is seconds. | |
Authentication method Default is none. |
