DUAConfSchemaOID は、1.3.6.1.4.1.11.1.3.1 です。
DESC 'Default LDAP server host address used by a DUA' EQUALITY caseIgnoreMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 SINGLE-VALUE ) ( DUAConfSchemaOID.1.1 NAME 'defaultSearchBase' DESC 'Default LDAP base DN used by a DUA' EQUALITY distinguishedNameMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.12 SINGLE-VALUE ) ( DUAConfSchemaOID.1.2 NAME 'preferredServerList' DESC 'Preferred LDAP server host addresses to be used by a DUA' EQUALITY caseIgnoreMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 SINGLE-VALUE ) ( DUAConfSchemaOID.1.3 NAME 'searchTimeLimit' DESC 'Maximum time in seconds a DUA should allow for a search to complete' EQUALITY integerMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 SINGLE-VALUE ) ( DUAConfSchemaOID.1.4 NAME 'bindTimeLimit' DESC 'Maximum time in seconds a DUA should allow for the bind operation to complete' EQUALITY integerMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 SINGLE-VALUE ) ( DUAConfSchemaOID.1.5 NAME 'followReferrals' DESC 'Tells DUA if it should follow referrals returned by a DSA search result' EQUALITY caseIgnoreIA5Match SYNTAX 1.3.6.1.4.1.1466.115.121.1.7 SINGLE-VALUE ) ( DUAConfSchemaOID.1.6 NAME 'authenticationMethod' DESC 'A keystring which identifies the type of authentication method used to contact the DSA' EQUALITY caseIgnoreMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 SINGLE-VALUE ) ( DUAConfSchemaOID.1.7 NAME 'profileTTL' DESC 'Time to live, in seconds, before a client DUA should re-read this configuration profile' 'serviceSearchDescriptor' DESC 'LDAP search descriptor list used by a DUA' EQUALITY caseExactMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 ) ( DUAConfSchemaOID.1.9 NAME 'attributeMap' DESC 'Attribute mappings used by a DUA' EQUALITY caseIgnoreIA5Match SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 ) ( DUAConfSchemaOID.1.10 NAME 'credentialLevel' DESC 'Identifies type of credentials a DUA should use when binding to the LDAP server' EQUALITY caseIgnoreIA5Match SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 SINGLE-VALUE ) ( DUAConfSchemaOID.1.11 NAME 'objectclassMap' DESC 'Objectclass mappings used by a DUA' EQUALITY caseIgnoreIA5Match SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 ) ( DUAConfSchemaOID.1.12 NAME 'defaultSearchScope' SINGLE-VALUE ) ( DUAConfSchemaOID.1.13 NAME 'serviceCredentialLevel' DESC 'Identifies type of credentials a DUA should use when binding to the LDAP server for a specific service' EQUALITY caseIgnoreIA5Match SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 ) ( DUAConfSchemaOID.1.15 NAME 'serviceAuthenticationMethod' DESC 'Authentication Method used by a service of the DUA' EQUALITY caseIgnoreMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 ) ( DUAConfSchemaOID.2.4 NAME 'DUAConfigProfile' SUP top STRUCTURAL DESC 'Abstraction of a base configuration for a DUA' MUST ( cn ) MAY ( defaultServerList $ preferredServerList $ defaultSearchBase $ defaultSearchScope $ searchTimeLimit $ bindTimeLimit $ credentialLevel $ authenticationMethod $ followReferrals $ serviceSearchDescriptor $ serviceCredentialLevel $ serviceAuthenticationMethod $ objectclassMap $ attributeMap $ profileTTL ) ) |
