Solaris のシステム管理 (ネーミングとディレクトリサービス : DNS、NIS、LDAP 編)
パスワード管理のために pam_ldap を構成した pam.conf ファイル例
# PAM configuration
# Authentication management
# login service (explicit because of pam_dial_auth)
login  auth     requisite pam_authtok_get.so.1
login  auth     required  pam_dhkeys.so.1
login  auth     required  pam_dial_auth.so.1
login  auth     binding   pam_unix_auth.so.1 server_policy
login  auth     required  pam_ldap.so.1
# rlogin service (explicit because of pam_rhost_auth)
rlogin  auth     sufficient pam_rhosts_auth.so.1
rlogin  auth     requisite  pam_authtok_get.so.1
rlogin  auth     required   pam_dhkeys.so.1
rlogin  auth     binding    pam_unix_auth.so.1 server_policy
rlogin  auth     required   pam_ldap.so.1
# rsh service (explicit because of pam_rhost_auth,
# and pam_unix_auth for meaningful pam_setcred)
rsh     auth sufficient         pam_rhosts_auth.so.1
rsh     auth required           pam_unix_auth.so.1
# PPP service (explicit because of pam_dial_auth)
ppp     auth requisite          pam_authtok_get.so.1
ppp     auth required           pam_dhkeys.so.1
ppp     auth required           pam_dial_auth.so.1
ppp     auth binding            pam_unix_auth.so.1 server_policy
ppp     auth required           pam_ldap.so.1
# Default definitions for Authentication management
# Used when service name is not explicitly mentioned for authentication
other   auth requisite          pam_authtok_get.so.1
other   auth required           pam_dhkeys.so.1
other   auth binding            pam_unix_auth.so.1 server_policy
other   auth required           pam_ldap.so.1
# passwd command (explicit because of a different authentication module)
passwd auth     binding   pam_passwd_auth.so.1 server_policy
passwd auth     required  pam_ldap.so.1
# cron service (explicit because of non-usage of pam_roles.so.1)
cron    account required        pam_projects.so.1
cron    account required        pam_unix_account.so.1
# Default definition for Account management
# Used when service name is not explicitly mentioned for account management
other  account  requisite pam_roles.so.1
other  account  required  pam_projects.so.1
other  account  binding   pam_unix_account.so.1 server_policy
other  account  required  pam_ldap.so.1
# Default definition for Session management
# Used when service name is not explicitly mentioned for session management
other   session required        pam_unix_session.so.1
# Default definition for Password management
# Used when service name is not explicitly mentioned for password management
other  password required  pam_dhkeys.so.1
other  password requisite pam_authtok_get.so.1
other  password requisite pam_authtok_check.so.1
other  password required  pam_authtok_store.so.1 server_policy
# Support for Kerberos V5 authentication (uncomment to use Kerberos)
#rlogin         auth optional           pam_krb5.so.1 try_first_pass
#login          auth optional           pam_krb5.so.1 try_first_pass
#other          auth optional           pam_krb5.so.1 try_first_pass
#cron           account optional        pam_krb5.so.1
#other          account optional        pam_krb5.so.1
#other          session optional        pam_krb5.so.1
#other          password optional       pam_krb5.so.1 try_first_pass
