This section provides information about how to deal with accessibility-related problems in the GNOME 2.0 Desktop.
Problem |
The numeric keypad stops responding when I enable XKB on a Solaris 8 or a Solaris 9 system. |
Solution |
Use the numeric keys in the main part of the keyboard. |
Problem |
This problem is displayed on Sun Ray systems only. When you enable the Mouse Keys feature, the 9 key on the numeric keypad should move the mouse pointer upwards and diagonally to the right. However, the 9 key moves the pointer straight upwards. |
Solution |
Press the 8 key to move the pointer upwards and press the 6 key to move the pointer to the right. |
