Solution
Perform the following
actions to prevent Nautilus from searching for
trash on a NFS file systems:
Edit the following file:
/usr/share/gnome/nautilus/filesystem-attributes.xml
Set the following entry:
filesystem name="nfs" _default_volume_name="NFS Network Volume"
trash="no"
Run the following command to restart Nautilus: pkill nautilus
