Solution
Perform the following
steps:
Open the Applications menu.
Choose CDE Menu -> Applications -> Audio Control.
Select the Playback tab, then turn on
one of the following devices that you want to listen to:
Built-in Speaker
Headphone
Line Out
Select the Record tab, then select Internal CD for the Master Input.
Adjust the monitor volume to a non-zero value.
You can now listen to CDs with the CD Player application.
Note –
This procedure might not work
on all Sun hardware and CD configurations.
