Problem
Bug ID 4821955, affects
Traditional Chinese locales.
You cannot see the characters displayed
with some special fonts such as bold fonts. As a result, some characters in
the Yelp window appear to be missing.
Solution
You must change the pangox.alias file in /etc/{zh_TW.EUC,zh_TW.BIG5,zh_TW.UTF-8,zh_HK.BIG5HK,zh_HK.UTF-8}. Perform the following steps:
Log in as root.
Change to the directory where thepangox.alias
file is located for your locale. For example, for the zh_TW.BIG5 locale,
run the following command:
cd /etc/pango/zh_TW.BIG5
Run the following command:
cat pangox.alias | tr [A-Z] [a-z] > /tmp/pango
mv /tmp/pango pangox.alias
If the directory /etc/pango/sparcv9/pango
is on your system, change the pangox.alias files. in
the locale subdirectories in that directory, in the same way as for /etc/pango.
