GNOME 2.0 Desktop for the Solaris Operating Environment Troubleshooting Guide
9.4.9 Localized Characters Do Not Display in gedit
Problem
For example: bug ID 4785550, affects Japanese locales.
Japanese characters do not display in the gedit application, when you select Courier as the default font.
Solution
Perform the following steps:
  • Open the gedit application.
  • Choose Edit -> Preferences.
  • Select Font & Colors in the Categories panel.
  • Select the option Use default theme font.
This solution does not fix the problem that IBC/NEC extended character and special characters are not displayed in the Solaris 8 operating environment.
