This section describes top-level directories on each DVD and CD.
The following figure shows the directories on the Solaris x86 Platform Edition DVD.
Slice 0 (s0) contains the Solaris 9 miniroot.
Slice 2 (s2) contains the Copyright and Solaris_9 directories. The Solaris_9 directory contains all the tools, software, and configuration information necessary to install the Solaris 9 software product. Slice 2 contains the following directories:
ExtraValue – Two subdirectories:
CoBundled – Fully supported Solaris products not directly part of the Solaris operating environment that includes Solaris Web Start Wizards SDK 3.0.1 and SunScreen 3.2
EarlyAccess – Preliminary evaluation software
Misc – The jumpstart_sample directory, which includes a rules file, a check script, profiles, begin scripts, finish scripts, and other JumpStart software and files.
Patches – All the Solaris 9 patches available at the time of this release.
Product – The Solaris 9 packages and control files.
Tools – The Solaris 9 installation tools, which include the following.
The Boot subdirectory that contains the Solaris 9 miniroot.
The scripts add_install_client, dial, rm_install_client, and setup_install_server
An Installers subdirectory that contains installers and supporting Java class files to install Solaris Live Upgrade and the Solaris Software 2 of 2 x86 Platform Edition CD. Solaris Live Upgrade is automatically installed when you install the Solaris software. However, in order to use Live Upgrade to upgrade from a previous Solaris release, you need to install these packages first on your current release. For instructions on installing Solaris Live Upgrade, see To Install Solaris Live Upgrade With the Solaris Web Start Installer.
A d1_image subdirectory that contains the Solaris Device Configuration Assistant software that can be copied to a diskette.
1of2_Doc_CD – Documentation for English and European Languages
2of2_Doc_CD – Documentation for Asian Languages
The following figure shows the directories on the Solaris Installation Multilingual x86 Platform Edition CD or Solaris x86 Platform Edition Installation CD.
The directory multi_icd_sol_x86 contains scripts that install the Solaris software and includes the Boot subdirectory for the Solaris 9 miniroot. The directories and scripts include the following:
Slice 2 (s2) contains scripts that install the Solaris software and a Boot subdirectory that contains the Solaris miniroot. These scripts include the following:
add_install_client
modify_install_server
rm_install_client
The following figures show the directory structure of the Solaris Software x86 Platform Edition CDs.
Slice 2 (s2) contains the Copyright and Solaris_9 directories. The Solaris_9 directory contains all the tools, software, and configuration necessary to install, at a minimum, the Solaris 9 software product, including the Core System Support and End User System Support software groups. The Solaris_9 directory contains the following directories:
Docs – Empty directory.
Patches – All the Solaris 9 patches available at the time the Solaris Software 1 of 2 x86 Platform Edition CD was created.
Tools – The Solaris 9 installation tools, which include a symbolic link to the boot miniroot on slice 0, add_install_client, dial, rm_install_client, and setup_install_server.
The following figure shows the directories on the Solaris Software 2 of 2 x86 Platform Edition CD.
The sol_x86_2 directory contains Copyright, Solaris Web Start installer, and Solaris_9 directories. The Solaris_9 directory contains the following:
Product – A limited number of packages, Developer System Support, Entire Distribution, and Entire Distribution Plus OEM Support software groups.
Tools – This directory includes the following:
The add_to_install_server script.
An Installers subdirectory that contains an installer and supporting Java class files to install Solaris Live Upgrade and the Solaris Software 2 of 2 x86 Platform Edition CD. Solaris Live Upgrade is automatically installed when you install the Solaris software. However, in order to use Live Upgrade to upgrade from a previous Solaris release, you need to install these packages first on your current release. For instructions on installing Solaris Live Upgrade, see To Install Solaris Live Upgrade With the Solaris Web Start Installer.
The following figure shows the directory structure of the Solaris x86 Platform Edition Languages CD.
The sol_lang_x86 directory contains the Solaris Web Start program, which installs the Solaris language and locale software. You can choose to install the nine languages in default directories or install specific languages. The sol_lang_x86 directory contains these directories:
Components – Contains SimplifiedChinese, French, German, Italian, Japanese, Korean, Spanish, Swedish, TraditionalChinese, and TraditionalChineseHongKong locale packages and also includes packages that are shared by all locales
Copyright – The copyright page
installer – The Web Start installer
Tools – The add_to_install_server script for creating an install server
For more information on locale software, see International Language Environments Guide.
