Solaris 9 9/04 Installation Guide
Validate the rules File
After the rules and profiles are set up, you run the check script to verify that the files are correct:
server-1# cd /jumpstart
server-1# ./check
If the check script does not find any errors, the script creates the rules.ok file.
