Solaris 9 9/04 Installation Guide
SPARC: Boot the Engineering Systems and Install Solaris 9 Software
After setting up the servers and files, you can boot the engineering systems by using the following boot command at the ok (PROM) prompt of each system:
ok boot net - install
The Solaris operating environment is automatically installed on the engineering group's systems.
