Solaris 9 9/04 Installation Guide
Chapter 5 System Requirements and Guidelines (Planning)
This chapter describes system requirements to install or upgrade to the Solaris operating environment. General guidelines for planning the disk space and default swap space allocation are also provided. This chapter contains the following sections:
Memory Requirements
To install or upgrade to the Solaris operating environment, the suggested memory size is 128 Mbytes or greater.
Note –
Some optional installation features are enabled only when sufficient memory is present. For example, if you install from a DVD with insufficient memory, you install through the Solaris Web Start installation program's command-line interface, not through the Web Start graphical user interface.
Allocating Disk Space
Before you install the Solaris 9 software, you can determine if your system has enough disk space by doing some high-level planning. If you plan your disk space needs before you install, you can add more disks to your system, if you need them, before you install the Solaris 9 software. If you are upgrading, review Upgrading With Disk Space Reallocation.
General Disk Space Planning and Recommendations
Planning disk space is different for everyone. Consider the following general points when you are planning disk space.
If you are using Solaris Live Upgrade, see Solaris Live Upgrade Disk Space Requirements.
Disk Space Recommendations for Software Groups
The Solaris software groups are collections of Solaris packages. Each software group includes support for different functions and hardware drivers. You select the software group to install, based on the functions that you want to perform on the system.
When you are installing the Solaris software, you can choose to add or remove packages from the Solaris software group that you selected. When you are selecting which packages to add or remove, you need to know about software dependencies and how the Solaris software is packaged.
The following table lists the Solaris software groups and the recommended amount of disk space that you need to install each group.
Note –
The following disk space recommendations include space for the following items.
You might find that the following software groups require less disk space than the amount that is listed in the following table.
Table 5–1 Disk Space Recommendations for Software Groups
Software Group
Recommended Disk Space
Entire Solaris Software Group Plus OEM Support
2.9 Gbytes
2.7 Gbytes
Developer Solaris Software Group
2.4 Gbytes
End User Solaris Software Group
2.0 Gbytes
Core System Support Software Group
2.0 Gbytes
SPARC: How Swap Space Is Allocated
By default, the Solaris installation programs allocate swap space by placing swap so that it starts at the first available disk cylinder (typically cylinder 0 on SPARC systems). This placement provides maximum space for the root (/) file system during the default disk layout and enables the growth of the root (/) file system during an upgrade. If you use the installation program's automatic layout of disk slices and avoid manually changing the size of the swap slice, the Solaris installation program allocates a default swap area of 512 Mbytes.
If you think you might need to expand the swap area in the future, you can place the swap slice so that it starts at another disk cylinder by using one of the following methods.
For an overview of the swap space, see “Configuring Additional Swap Space (Tasks)” in System Administration Guide: Devices and File Systems.
Requirements When Using the Solaris Installation CD
When you are installing or upgrading by using the Solaris Installation CD, there are special requirements for SPARC slices and x86 fdisk partitions. When you are installing from a DVD or a net installation image, these requirements are not necessary.
Table 5–2 Solaris Installation CD Requirements
Platform
Requirements
Slice requirements for upgrading
When you use the Solaris Installation CD and the Solaris Web Start program to upgrade, you must have a slice on the disk that does not store files. The swap slice is preferred, but you can use any slice that is not located in any of the “upgradable” root slices that are listed in /etc/vfstab. The size of this slice must be at least 512 Mbytes.
x86 systems fdisk partition requirements
When you use the Solaris Installation CD, the Solaris Web Start program requires two fdisk partitions on the system disk to perform an installation or upgrade.
  • Solaris fdisk partition
    This is the typical Solaris fdisk partition. If you do not have a Solaris fdisk partition on your system, the Solaris Web Start program prompts you to create one.
    Caution: If you change the size of an existing fdisk partition, all data on that partition is automatically deleted. Back up your data before you create a Solaris fdisk partition.
  • x86 boot fdisk partition
    This is a 10–Mbyte fdisk partition that enables the x86 architecture to boot the miniroot that is placed on the newly created swap slice that is located on the Solaris fdisk partition.
    Caution: Do not create the x86 boot partition manually.
    The Solaris Web Start installation program creates the x86 boot partition by removing 10 Mbytes from the Solaris fdisk partition. By allowing the installation program to create the x86 boot partition, you prevent any existing fdisk partitions from being altered.
Note –
If you install or upgrade a system that has a Service partition, the Solaris Web Start installation program preserves the Service partition and creates the Solaris and x86 boot fdisk partitions. For more information on preserving a Service partition, see x86: Change in Default Boot-Disk Partition Layout.
x86 system upgrade limitations
When you use the Solaris Installation CD, you cannot use the Solaris Web Start program to upgrade from the Solaris 2.6 or Solaris 7 operating environments. The Solaris Installation CD requires a separate 10–Mbyte x86 boot partition that was not required in the Solaris 2.6 or Solaris 7 releases. You must use the Solaris Web Start program from a DVD or a net installation image, or use the Solaris suninstall program or custom JumpStart to upgrade.
x86 systems logical block addressing requirement
Do not use the Solaris Installation CD unless your system can boot across the 1024–cylinder limit. Logical block addressing (LBA) enables the machine to boot beyond the 1024–cylinder limit and across Solaris disk slices. Use the Solaris Installation CD when your system's BIOS and SCSI driver for the default boot disk supports LBA.
To determine if your system supports LBA, type:
# prtconf -pv | grep -i lba
If the BIOS and SCSI driver for the default boot disk support LBA, the following message appears.
lba-access-ok:
If the SCSI driver for the default boot disk does not support LBA, the following message appears.
no-bef-lba-access
If the BIOS and SCSI driver for the default boot disk do not support LBA, use the Solaris DVD or a net installation image to install or upgrade.
In the Solaris 9 (x86 Platform Edition) operating environment, the Solaris Web Start and suninstall installation programs use a new default boot-disk partition layout to accommodate the Service partition. If your system currently includes a Service partition, the new default boot-disk partition layout enables you to preserve this partition.
Note –
If you install the Solaris 9 (x86 Platform Edition) operating environment on a system that does not currently include a Service partition, the installation program does not create a new Service partition by default. If you want to create a Service partition on your system, see your hardware documentation.
The new default includes the following partitions.
If you want to use this default layout, select Default when the installation program asks you to choose a boot-disk layout.
