Task |
Description |
For Instructions |
Install your chosen software configuration on the master system |
Determine the configuration that meets your needs and use any of the Solaris installation methods to install the master system. | |
(Optional) Create customization scripts |
Determine if you need to create scripts to do the following:
Create the Solaris Flash archive |
Use the flar create command to create an archive. |
To Create a Solaris Flash Archive for an Initial Installation |
(Optional) Save a copy of the archive |
Keep a copy of the archive for future comparison to update a clone system with a differential archive. |
Table 21–2 Task Map: Creating a Solaris Flash Archive to Update a Clone System
Task |
Description |
For Instructions |
Prepare master image |
Make changes to the unchanged master image such as adding or deleting packages or installing patches. | |
Create the Solaris Flash differential archive |
To Create a Solaris Flash Differential Archive With an Updated Master Image |
