Solaris 9 9/04 Installation Guide
Guidelines for Creating a Custom Script
When creating a scripts other than the reboot script, following these guidelines to assure the script does not corrupt the operating environment or otherwise disrupt the system. These guidelines enable the use of Solaris Live Upgrade, which creates a new boot environment for installation of the operating environment. The new boot environment can be installed with an archive while the current system is running.
Note –
These guidelines are not for reboot scripts that are allowed to run daemons or make other types of modification to the root (/) file system.
For an overview of Solaris Live Upgrade, see Chapter 33, Solaris Live Upgrade (Overview).
