Network
Is the system connected to a network?
Yes/No
DHCP
Can the system use Dynamic Host Configuration Protocol (DHCP) to configure its network interfaces?
Yes/No
Host Name
Host name that you choose for the system.
IP Address
If you are not using DHCP, supply the IP address for the system.
Example: 192.168.9.1
Subnet
If you are not using DHCP, is the system part of a subnet?
If yes, what is the netmask of the subnet?
Example: 255.255.0.0
Yes/No
IPv6
Do you want to enable IPv6 on this machine?
Yes/No
Kerberos
Do you want to configure Kerberos security on this machine?
If yes, gather this information:
Yes/No
Default Realm:
Administration Server:
First KDC:
(Optional) Additional KDCs:
Name Service
Which name service should this system use?
NIS+/NIS/DNS/LDAP/None
Domain Name
If the system uses a name service, supply the name of the domain in which the system resides.
NIS+ and NIS
Do you want to specify a name server or let the installation program find one?
If you want to specify a name server, provide the following information.
Specify One/Find One
Server's host name:
Server's IP Address:
DNS
Provide IP addresses for the DNS server. You must enter at least one IP address, but you can enter up to three addresses.
Server's IP Address(es):
You can enter a list of domains to search when a DNS query is made.
Search Domain:
LDAP
Provide the following information about your LDAP profile.
Profile Name:
Profile Server:
IP Address:
If you specify a proxy credential level in your LDAP profile, gather this information.
Proxy-bind distinguished name:
Proxy-bind password:
Default Route
Do you want to specify a default route IP address or let the Solaris Web Start installation program or Solaris suninstall program find one?
The default route provides a bridge that forwards traffic between two physical networks. An IP address is a unique number that identifies each host on a network.
You have the following choices:
You can specify the IP address. An /etc/defaultrouter file is created with the specified IP address. When the system is rebooted, the specified IP address becomes the default route.
You can let the software detect an IP address.
The Solaris suninstall program detects an IP address when the system is rebooted.
The Solaris Web Start installation program can detect a default route. However, the system must be on a subnet that has a router that advertises itself by using the ICMP router discovery protocol.
You can choose None if you do not have a router or do not want the software to detect an IP address at this time. The software automatically tries to detect an IP address on reboot.
Specify One/Find One/None
Host IP address:
Time Zone
How do you want to specify your default time zone?
Geographic region
Offset from GMT
Time zone file
Locales
For which geographic regions do you want to install support?
SPARC: Power Management
(only available on SPARC systems that support Power Management)
Do you want to use Power Management?
Note –
If your system has Energy Star version 3 or later, you are not prompted for this information.
Yes/No
Proxy Server Configuration
(only available in the Solaris Web Start program)
Do you have a direct connection to the Internet or do you need to use a proxy server to gain access to the Internet?
If you use a proxy server, provide the following information.
Direct Connection/Proxy Server
Host:
Port:
Automatic reboot or CD/DVD ejection
Reboot automatically after software installation?
Eject CD/DVD automatically after software installation?
Yes/No
Yes/No
Disk Space Reallocation
Do you want the installation program to automatically re-lay out file systems on your disks?
If yes, which file systems should be used for auto-layout?
Example: /, /opt, /var
If no, you must provide information for file system configuration.
Yes/No
SPARC: 64–bit
Do you want to install support for 64–bit applications?
Yes/No
