Solaris 9 9/04 Installation Guide
Profile Keywords at a Glance
Table 31–2 provides a quick way to determine which keywords you can use, based on your installation scenario. Unless otherwise noted in the keyword descriptions, the keyword can only be used with the initial installation option.
Table 31–2 Overview of Profile Keywords
Installation Scenarios
Profile Keywords
Standalone System (Nonnetworked)
Standalone System (Networked) or Server
OS Server
Upgrade
Upgrade With Disk Space Reallocation
archive_location (installing Solaris Flash archives)
backup_media
boot_device
bootenv createbe
client_arch
client_root
client_swap
cluster (adding software groups)
cluster (adding or deleting clusters)
dontuse
fdisk (x86 only)
filesys (mounting remote file systems)
filesys (creating local file systems)
filesys (creating mirrored file systems)
forced_deployment (installing Solaris Flash differential archives)
geo
install_type
isa_bits
layout_constraint
local_customization (installing Solaris Flash archives)
locale
metadb (creating state database replicas)
no_master_check (installing Solaris Flash differential archives)
no_content_check (installing Solaris Flash differential archives)
num_clients
package
partitioning
root_device
system_type
usedisk
