You can use environment variables in your begin and finish scripts. For example, a begin script might extract the disk size, SI_DISKSIZES, and install or not install particular packages on a system, based on the actual disk size the script extracts.
Information that is gathered about a system is stored in these environment variables, which are generally set or not, depending on the rule keywords and values you use in the rules file.
For example, information about which operating system is already installed on a system is only available in SI_INSTALLED after the installed keyword is used.
Table 31–7 describes these variables and their values.
Table 31–7 Installation Environment Variables|
Environment Variable |
Value |
CHECK_INPUT |
The path to the rules file in the JumpStart directory, which is mounted on /tmp/install_config/rules. |
HOME |
The root's home directory during installation, which is /tmp/root. |
PATH |
The shell search path during installation, which is /sbin:/usr/sbin/install.d:/usr:/usr/sbin:/usr/bin. |
SI_ARCH |
The hardware architecture of the install client. The SI_ARCH variable is set when the arch keyword is used in the rules file. |
SI_BEGIN |
The name of the begin script, if one is used. |
SI_CLASS |
The name of the profile that is used to install the install client. |
SI_CONFIG_DIR |
The path to the JumpStart directory, which is mounted on /tmp/install_config. Note – The SI_CONFIG_DIR variable is not available for custom JumpStart installations that use the WAN boot installation method. |
SI_CONFIG_FILE |
SI_CONFIG_PROG |
The rules file. |
SI_CUSTOM_PROBES_FILE |
The custom_probes.ok file, in which you can define your own rule and probe keywords. If you create a custom_probes.ok file, you can use the file to extend the list of default rule keywords, which are described in Rule Keywords and Values. You can also use the file to extend the list of default probe keywords that are described in Probe Keywords and Values. |
SI_DISKLIST |
A comma-separated list of disk names on the install client. The SI_DISKLIST variable is set when the disksize keyword is used and matched in the rules file. The SI_DISKLIST and SI_NUMDISKS variables are used to determine the physical disk to use for the rootdisk. rootdisk is described in How the System's Root Disk Is Determined. |
SI_DISKSIZES |
A comma-separated list of disk sizes on the install client. The SI_DISKSIZES variable is set when the disksize keyword is used and matched in the rules file. |
SI_DOMAINNAME |
The domain name. The SI_DOMAINNAME variable is set when the dommainname keyword is used and matched in the rules file. |
SI_FINISH |
The name of the finish script, if one is used. |
SI_HOSTADDRESS |
The install client's IP address. |
SI_HOSTID |
The install client's Ethernet address. |
SI_HOSTNAME |
The install client's host name. The SI_HOSTNAME variable is set when the hostname keyword is used and matched in the rules file. |
SI_INSTALLED |
The device name of a disk with a specific operating system on the disk, for example, Solaris, SunOS, or System V. The SI_INSTALLED variable is set when the installed keyword is used and matched in the rules file. SI_INST_OS and SI_INST_VER are used to determine the value of SI_INSTALLED. |
SI_INST_OS |
The name of the operating system. SI_INST_OS and SI_INST_VER are used to determine the value of SI_INSTALLED. |
SI_INST_VER |
The version of the operating system. SI_INST_OS and SI_INST_VER are used to determine the value of SI_INSTALLED. |
SI_KARCH |
The install client's kernel architecture. The SI_KARCH variable is set when the karch keyword is used and matched in the rules file. |
SI_MEMSIZE |
The amount of physical memory on the install client. The SI_MEMSIZE variable is set when the memsize keyword is used and matched in the rules file. |
SI_MODEL |
The install client's model name. The SI_MODEL variable is set when the model keyword is used and matched in the rules file. |
SI_NETWORK |
The install client's network number. The SI_NETWORK variable is set when the network keyword is used and matched in the rules file. |
SI_NUMDISKS |
The number of disks on an install client. The SI_NUMDISKS variable is set when the disksize keyword is used and matched in the rules file. The SI_NUMDISKS and SI_DISKLIST variables are used to determine the physical disk to use for the rootdisk. rootdisk is described in How the System's Root Disk Is Determined. |
SI_OSNAME |
The operating system release on the Solaris 9 software image. For example, you can use the SI_OSNAME variable in a script if you are installing the Solaris software on systems that are based on the version of the operating system on the Solaris DVD or the Solaris Software 1 of 2 CD image. |
SI_PROFILE |
The path to the profile in the mounted JumpStart directory. The path is /tmp/install_config/profile_name. If you are creating a derived profile, SI_PROFILE is set to the /tmp/install.input file. |
SI_ROOTDISK |
The device name of the disk that is represented by the logical name rootdisk. The SI_ROOTDISK variable is set when the disksize or the installed keyword is set to rootdisk in the rules file. |
SI_ROOTDISKSIZE |
The size of the disk that is represented by the logical name rootdisk. The SI_ROOTDISKSIZE variable is set when the disksize or the installed keyword is set to rootdisk in the rules file. |
SI_SYS_STATE |
The /a/etc/.sysIDtool.state file. You can edit this file in a finish script to prevent the sysidroot program from prompting for a root password before the system reboots. |
SI_TOTALDISK |
The total amount of disk space on the install client. The SI_TOTALDISK variable is set when the totaldisk keyword is used and matched in the rules file. |
SHELL |
The default shell during installation, which is /sbin/sh. |
TERM |
The install client's terminal type. |
TZ |
The default time zone, as specified in the NIS or NIS+ name service. |
