Solaris 9 9/04 Installation Guide
Starting and Stopping Solaris Live Upgrade (Character Interface)
This procedure starts and stops the Solaris Live Upgrade menu program.
To Start Solaris Live Upgrade Menus
Note –
When viewing the character interface remotely, such as over a tip line, you might need to set the TERM environment variable to VT220. Also, when using the Common Desktop Environment (CDE), set the value of the TERM variable to dtterm, rather than xterm.
  1. Log in as superuser.
  2. Type:
    # /usr/sbin/lu
    The Solaris Live Upgrade main menu is displayed.
    Figure 35–2 Solaris Live Upgrade Main Menu
    The screen capture shows Solaris Live Upgrade tasks and the Enter and Help keys.
To Stop Solaris Live Upgrade Menus
  1. From the main menu, select Exit.
