Solaris 9 9/04 Installation Guide
To Create a Boot Environment From a Different Source (Command-Line Interface)
The lucreate command creates a boot environment that is based on the file systems in the active boot environment. If you want to create a boot environment based on a boot environment other than the active boot environment, use lucreate with the -s option.
Note –
If you activate the new boot environment and need to fall back, you boot back to the boot environment that was last active, not the source boot environment.
  1. Log in as superuser.
  2. Create the boot environment.
    # lucreate [-A 'BE_description'] -s source_BE_name
    -m mountpoint:device[,metadevice]:fs_options -n BE_name
    -A 'BE_description'
    (Optional) Enables the creation of a boot environment description that is associated with the boot environment name (BE_name). The description can be any length and can contain any characters.
    -s source_BE_name
    Specifies the source boot environment for the new boot environment. The source would not be the active boot environment.
    -m mountpoint:device[,metadevice]:fs_options [-m...]
    Specifies the file systems' configuration of the new boot environment. The file systems that are specified as arguments to -m can be on the same disk or they can be spread across multiple disks. Use this option as many times as needed to create the number of file systems that are needed.
    • mountpoint can be any valid mount point or – (hyphen), indicating a swap partition.
    • device field can be one of the following:
      • The name of a disk device, of the form /dev/dsk/cwtxdysz
      • The name of a Solaris Volume Manager metadevice, of the form /dev/md/dsk/dnum
      • The name of a Veritas Volume Manager volume, of the form /dev/vx/dsk/volume_name
      • The keyword merged, indicating that the file system at the specified mount point is to be merged with its parent
    • fs_options field can be one of the following:
      • ufs, which indicates a UFS file system.
      • vxfs, which indicates a Veritas file system.
      • swap, which indicates a swap file system. The swap mount point must be a – (hyphen).
      • For file systems that are logical devices (mirrors), several keywords specify actions to be taken on the file systems. These keywords can create a logical device, change the configuration of a logical device, or delete a logical device. For a description of these keywords, see To Create a Boot Environment With RAID-1 Volumes (Mirrors) (Command-Line Interface).
    -n BE_name
    The name of the boot environment to be created. BE_name must be unique on the system.
    Example 35–7 Creating a Boot Environment From a Different Source (Command-Line Interface)
    In this example, a boot environment is created based on the root (/) file system in the source boot environment named third_disk. Third_disk is not the active boot environment. A description, mydescription, is associated with the new boot environment named second_disk.
    # lucreate -A 'mydescription' -s third_disk \
    -m /:/dev/dsk/c0t4d0s0:ufs  -n second_disk
    When creation of the new boot environment is complete, it can be upgraded and activated (made bootable). See Chapter 36, Upgrading With Solaris Live Upgrade (Tasks).
