Use either the Delete menu or ludelete. You cannot delete the active boot environment or the boot environment that is activated on the next reboot. The boot environment to be deleted must be complete. A complete boot environment is not participating in an operation that will change its status. Use Displaying the Status of All Boot Environments to determine a boot environment's status. Also, you cannot delete a boot environment that has file systems mounted with lumount.
From the main menu, select Delete.
Type the name of the inactive boot environment you want to delete:
Name of boot environment: solaris8 |
The inactive boot environment is deleted.
Log in as superuser.
Type:
# ludelete BE_name |
Specifies the name of the inactive boot environment that is to be deleted
In this example, the boot environment, second_disk, is deleted.
# ludelete second_disk |
