The following sections list packages required by Solaris Live Upgrade and provide information on recommended patches. See Upgrading a System With Packages and Patches for information on using Solaris Live Upgrade to add packages and patches.
When upgrading and adding and removing packages or patches, Solaris Live Upgrade requires packages or patches that comply with the SVR4 Advanced Packaging Guidelines. While Sun packages conform to these guidelines, Sun cannot guarantee the conformance of packages from third-party vendors. If a package violates these guidelines, the package can cause the package-addition software during an upgrade to fail or alter the active boot environment.
For more information on adding and removing packages with Solaris Live Upgrade, see the man page, luupgrade(1M). For more information on packaging requirements, see Appendix G, Additional SVR4 Packaging Requirements (Reference).
Check your current operating environment for the packages in the following table, which are required to use Solaris Live Upgrade. If packages in the column for your release are missing, use the pkgadd command to add the packages.
Table 34–2 Required Packages for Solaris Live Upgrade|
Solaris 2.6 Release |
Solaris 7 Release |
Solaris 8 Release |
SUNWadmap |
SUNWadmap |
SUNWadmap |
SUNWadmc |
SUNWadmc |
SUNWadmc |
SUNWjvrt |
SUNWjvrt |
SUNWj2rt |
SUNWlibC |
SUNWlibC |
SUNWlibC |
SUNWadmfw |
SUNWbzip |
SUNWmfrun |
SUNWloc |
To check for packages on your system, type the following command.
% pkginfo [[package_name]] |
You can use Solaris Live Upgrade to add patches and packages to a system. By using Solaris Live Upgrade to add patches to a machine, the only downtime the system incurs is that of a reboot. You can add patches and packages to a boot environment with the luupgrade command or with a Solaris Flash archive.
To add patches to a boot environment directly, create a new boot environment and use the luupgrade command with the -t option. To add packages to a boot environment, use the luupgrade command with the -p option. For more information, see the man page, luupgrade(1M).
Or, you can use Solaris Live Upgrade to install a Solaris Flash archive. An archive contains a complete copy of a boot environment with new packages and patches already included. This complete boot environment or single reference system is called a master system. The process of creating a Solaris Flash archive begins with creating a master system. After you have created a master system, add any patches and packages that you want to install. Then, create a Solaris Flash archive of the master system. Use Solaris Live Upgrade to install the archive on the new boot environment. You can copy the boot environment and change and distribute the boot environment as many times as necessary. For details about how to create a Solaris Flash archive, see Chapter 21, Creating Solaris Flash Archives (Tasks). For information on using Solaris Live Upgrade to install a Solaris Flash archive, see Installing Solaris Flash Archives on a Boot Environment.
When upgrading and adding and removing packages or patches, Solaris Live Upgrade requires packages or patches that comply with the SVR4 advanced packaging guidelines. While Sun packages conform to these guidelines, Sun cannot guarantee the conformance of packages from third-party vendors. If a package violates these guidelines, the package can cause the package-addition software to fail or can alter the active boot environment.
Correct operation of Solaris Live Upgrade requires that a limited set of patch revisions be installed for a given OS version. Before installing or running Live Upgrade, you are required to install a limited set of patch revisions. Make sure you have the most recently updated patch list by consulting http://sunsolve.sun.com. Search for the info doc 72099 on the SunSolveSM web site.
