Solaris 9 9/04 Installation Guide
To Install a Solaris Flash Archive on a Boot Environment (Command-Line Interface)
  1. Log in as superuser.
  2. Type:
    # luupgrade -f -n BE_name -s os_image_path -a archive
    -f
    Indicates to install an operating system from a Solaris Flash archive.
    -n BE_name
    Specifies the name of the boot environment that is to be installed with an archive.
    -s os_image_path
    Specifies the path name of a directory that contains an operating system image. This directory can be on an installation medium, such as a DVD-ROM, CD-ROM, or it can be an NFS or UFS directory.
    -a archive
    Path to the Solaris Flash archive when the archive is available on the local file system. The operating system image versions specified with the -s option and the -a option must be identical.
    Example 36–7 Installing Solaris Flash Archives on a Boot Environment (Command-Line Interface)
    In this example, an archive is installed on the second_disk boot environment. The archive is located on the local system. The operating systems versions for the -s and -a options are both Solaris 9 releases. All files are overwritten on second_disk except shareable files.
    # luupgrade -f -n second_disk \
    -s /net/installmachine/export/Solaris_9/OS_image \
    -a /net/server/archive/Solaris_9
    The boot environment is ready to be activated.
