Solaris 9 9/04 Installation Guide
Creating a Boot Server on a Subnet With a CD Image
You must create an install server to install the Solaris software on a system from the network. You do not always need to set up a boot server. A boot server contains enough of the boot software to boot systems from the network, and then the install server completes the installation of the Solaris software.
To Create a Boot Server on a Subnet With a CD Image
  1. On the system you intend to make the boot server for the subnet, log in and become superuser.
    The system must include a local CD-ROM drive or have access to the remote Solaris 9 disc images, which are normally on the install server. If you use a name service, the system should be in the name service. If you do not use a name service, you must distribute information about this system by following your site's policies.
  2. Mount the Solaris Software 1 of 2 CD image from the install server.
    # mount -F nfs -o ro server_name:path /mnt
    server_name:path
    Is the install server name and absolute path to the disc image
  3. Create a directory for the boot image.
    #  mkdir -p boot_dir_path
    boot_dir_path
    Specifies the directory where the boot software is to be copied
  4. Change to the Tools directory on the Solaris Software 1 of 2 CD image.
    # cd /mnt/Solaris_9/Tools
  5. Copy the boot software to the boot server.
    # ./setup_install_server -b boot_dir_path
    -b
    Specifies to set up the system as a boot server
    boot_dir_path
    Note –
    The setup_install_server command indicates whether you have enough disk space available for the images. To determine available disk space, use the df -kl command.
  6. Change directories to root (/).
    # cd /
  7. Unmount the installation image.
    # umount /mnt
You are now ready to set up systems to be installed from the network. See Adding Systems to Be Installed From the Network With a CD Image.
Example 15–5 Creating a Boot Server on a Subnet With CD Media
The following example illustrates how to create a boot server on a subnet. These commands copy the boot software from the Solaris Software 1 of 2 SPARC Platform Edition CD image to /export/install/boot on the system's local disk.
# mount -F nfs -o ro crystal:/export/install/boot /mnt
# mkdir -p /export/install/boot
# ./setup_install_server -b /export/install/boot
# cd /
# umount /mnt
In this example, the disc is inserted and automatically mounted before the command. After the command, the disc is removed.
