Solaris 9 9/04 Installation Guide
Compressed Configuration File Example
The following example shows how to use the tar command to create a compressed configuration file that is named config.tar. The custom JumpStart configuration files are located in the /jumpstart directory.
Example 27–6 Creating a Compressed Configuration File
# cd /jumpstart
# tar -cvf config.tar *
a profile 1K
a rules 1K
a rules.ok 1K
a sysidcfg 1K
